mmap
2022 MachE Route1
Software Guy
The 2022 owners manual is out. I have too much time on my hands waiting for a build date, so I took the PDFs of the 2021 and 2022 manuals, extracted the text, and diff'd them.
You can check out the differences here (for now): https://mmediff.tiiny.site/ (I've also attached the zip'd HTML in case that free site goes away.)
So far I haven't seen anything super interesting, but what else will I do with my 3-6 months left?
For nerds, here's how this was generated:
Bash:
pip install pdfminer
npm install -g diff2html-cli
pdf2txt.py -o 2021.txt 2021.pdf
pdf2txt.py -o 2022.txt 2022.pdf
sed -i 's|202. Mustang Mach-E (CGW) Canada/United States of America, enUSA, Edition date:.*First-Printing|202_  Mustang Mach-E (CGW) Canada/United States of America, enUSA, Edition date: _, First-Printing|g' 2021.txt 2022.txt
sed -i 's|^[1-9][0-9]$||g' 2021.txt 2022.txt
sed -i 's|^[1-5][0-9][0-9]$||g' 2021.txt 2022.txt
diff -wurd 2021.txt 2022.txt > diff.diff
diff2html --su -s side --lm words -i file --hc false -F mmediff.html diff.diff
mmap
mmap
2022 MachE Route1
Software Guy
2 alarm/security things that seem to have been removed from 22s:
WHAT IS THE PERIMETER ALARM
The perimeter alarm is designed to detect
unauthorized access to your vehicle.
WHAT IS THE BATTERY BACKUP
ALARM
The battery backup alarm is an additional
alarm system that has its own battery and
horn. It is designed to detect if the vehicle
battery or the battery backup alarm is
disconnected.
MY21 J1 Premium RWD SR
Probably related to this, they also removed the text regarding using the door touchpads to open unlocked doors during the first roughly 72 hours of a 12V battery failure. This was a feature described in late 2019 that never made it to production, just like the battery back up for the alarm.
2022 adds text that implies the frunk has power open and close. I doubt this is true? Maybe copy/paste from the F-150 mega power frunk:
Note: The front luggage compartment hood​
only operates with the transmission in park​
(P). If there is a problem with open or close
request, a tone sounds and a warning​
message appears in the instrument cluster.​
Note: Do not hang any weight from the​
front luggage compartment hood. This​
could damage the hood and its​
components. Remove any excessive weight​
from the hood prior to use. If the hood starts​
to close after it has fully opened, this​
indicates there may be excessive weight on​
the hood or a possible strut failure. A​
repetitive tone sounds and the hood closes
under control. If the hood continues to close​
after opening, have the system checked by​
an authorized dealer.​
Ah, yes. The illusive super-capacitors.
What 2021 manual are you comparing to? Job 1 with supplement. Job 2?
mmap
mmap
2022 MachE Route1
Software Guy
Wait so this didn’t end up being a thing? So we are totally hosed if there is a 12V battery failure? Can I be trapped in the car?
The interior levers have a manual linkage, so you won‘t be trapped inside. It’s getting in from the outside that adds a bit of a challenge.
RedDragon
22 Mach E AWD Premium Ext Bat - Rapid Red
If true power close on front frunk would be great
tesla2mme
Tony
California (Bay)
MME GT in the best color ever made (cyber orange!)
Anything about the 5 second power shut off lol
mmap
mmap
2022 MachE Route1
Software Guy
No, in fact even in the 2022 manual the instrument cluster section doesn't show or talk about the power meter at all.
