Disable Sirius XM popup?
Sobmartin
Leavenworth wa
Ford F-150, Prius Prime
Is there any way to disable Sirus so it doesn’t magically start up when I start the car. I usually have music running from a USB plugged in but Sirus starts up instead.
Neil4Real
Have it on the Android Auto or CarPlay window instead, but it might always default back to radio if you don't actually play anything from CarPlay/AA, so you'd have to just pick a station that you're fine with it doing it on.
Hammered
SE US
2022 PB F150, MME GTPE
When it comes on, push the button in the wheel to turn the 'radio' off. It should stay that way.
Mockey313
Detroit
2021 Mach E.
Usually happens when your phone's audio source takes too long to connect. It happens less when I have the app that I use for audio open on the phone when I start the car.
