bmwhitetx
- Bruce
- Jan 12, 2022
- Texas
- 2022 F-150 Lightning Lariat ER
In looking at my last pic, the connector that has the 2 brown and 2 black wires is likely the sensor loop. Looks like there is a release tab above the middle brown wires. I would disconnect this connector to disable.
The other connector with the purple/black, green/yellow, and blue/red wires is likely power, ground, and signal to the BCM. If you disconnect it, you will may throw a DTC or two on the BCM module. Or it could just act like a switch and only send a signal when it senses motion so also okay to disconnect.
