DrAchoo
- Jason
- Aug 17, 2021
- Oregon
- Premium Rapid Red RWD, St. Batt Mach E
I've had my Mach-E for 48 hours, but I have extensive 1-PD experience on a Chevy Volt so it didn't take long to accommodate to the much more aggressive regenerative braking and actual stopping ability that 1-PD offers on the Mach-E (I do sorta miss a brake paddle though). However, I am finding it challenging when I actually use the brake to not cause sudden braking that isn't smooth. A prime example would be when I am traveling at low speeds close to an intersection and realize that I will not be able to stop in the desired distance with the 1-PD only. I then try to lightly touch the brake pedal and find many times that I suddenly stop 10 feet short and probably make the driver behind me annoyed. It isn't so crazy as to mimic me slamming on the brakes, but the usual sensation that you get with a brake pedal where you can feel the engagement of the brakes and then use further pressure accordingly seems to be missing.
Do I need to just give it more time? Are others feeling this way as well?
