- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
I am wondering if the top speed is limited by motor rpm, inverter current, RW vs AWD, battery voltage, or just by Software....
I have noticed that my MME has limit of 113 mph.... certainly fast enough, but of course I would like to know if it is the same across various models and configurations.... and if it might be one of the magic FirmWare settings that somebody will eventually find out how to remove or change. I will also add that I was amazed how smooth the acceleration was, and the stability of the MME is pretty darn good... It's hard to tell the difference between 75mph and 100, especially with lack of noise or vibration in the cabin !
My first guess is that it may well be an actual hard limit set to protect the motor(s) from over-revving. But we can't see the actual motor rpm, nor do we know what that limit my be. I'm thinking this may result in different top speeds for various configurations of MME with different motor(s). i.e. does RWD have a higher top speed, or AWD, or does that not matter?
Second physical variable would be the SR vs ER battery, with the ER having slightly higher voltage, you might have more available power at same current if the top speed is current limited....
or, maybe its just a software/firmware limit baked into the controller ?
I did find this link
https://ev-database.org/imp/cheatsheet/top-speed-electric-car
indicating that all trims and configurations of the MME are limited to 112, except the GT, which is supposed to be opened up to 124.
so, for those of you who may 'test the limits' for real, I'd be curious to see your responses with top speeds for various configurations. ***disclaimer*** this is for entertainment purposes only, and should only be attempted on a closed course or private road.
I'll start with mine, which verifies the published limt:
MME Select AWD SR = 113 mph
MME Select AWD ER = ....same...
MME Select RWD SR =....same...
MME Select RWD ER =....same...
....same...
......... ok, ok, ok.... all are 112-113 mph limited by motor rpm parameter programmed into motor controller...... GT may be different since motor(s) used in GT may allow higher slightly higher rpm.
I'm sure that 'eventually' there will be controller hacks available.... but would obviously void stock warranty.
- Dan
....same...
- Dan
