Av8tor
- Kevin
- Aug 6, 2021
- Richmond, VA
- Fusion Hybrid, MME GTPE
- Systems Engineer IOT
So, did my first 7 hour trip from Richmond, VA to Cleveland, OH! Ring the First Timer Bell!
Used the Ford Navigation, Default was fastest route, going to Cleveland It routed me to 2 EVGo stations, which are out of network. Is this normal?
At the station below, my MME would not connect to the 350 (tall Signet) charger, No communications at all, tried strating from the station, then the app, nothing, Moved to the 100 kw (Squatty Delta) station, and everything worked.
Now, to add more intrigue, the station you see below had a MME charge to 80% and left, and I even slid over and tried again to connect and NO CHARGE FOR ME.
Any Ideas?
On the way home, the Ford Navigation picked 3 EA stations. First 2 worked like a champ, the 3rd WAS A DISASTER only 2 stations out of 6 worked. the folks charging there told me it's been that way for months. I called EA, and they said they know.. Anyway, both individuals left early to let me get enough charge to make it home.
I also noticed that the Ford Nav will swap in/out chargers as it deems necessary. I think the final station was different then when I first routed, but dont' remember if I was told there was a change..
Thoughts?
Any Ideas?
Thoughts?
