Faint clicking noise
Red Baron
Mel
2022 Mach-E Premium 2WD Standard Range
Realtor
New noise from Mach-E parked in my garage.
I am used to the clacking noise from the Mach-E when parked in my garage.
But, recently, I am hearing a faint clicking noise - almost like the sound of keys clicking in my pocket.
Anyone know what that could be?
bFWEAD
Bob
SoCal
2021 Mustang Mach-E
Look around front and check the active shutters. Last time I heard a clicking like you describe was right before I found that one of the active shutters on the front had been stuck and eventually broke itself. There was no evidence of impact or foreign debris, just the marks of torqueing before the plastic finally broke. Haven't heard it since.
Red Baron
Red Baron
Mel
Realtor
Shutters look ok
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
Do you have your Fob or PAAK on your person when you hear the clicking. It could be your car waking up, when you pass by. Relays and such energizing.
Marcel
The Netherlands
Woodworker
Most likely coolant hoses and their valves or a relais.
Red Baron
Red Baron
Mel
Realtor
Yes, I have my Fob.
But, this is a new noise. In the past, I have herd pretty loud clicking/clacking - relays, etc.
But, this is a faint sound - almost like the sound of coins clicking in your pocket.
Red Baron
Red Baron
Mel
Realtor
It happens when I enter the garage even without my Fob or my phone. I wonder if there is some kind of proximity detector?
Red Baron
Red Baron
Mel
Realtor
Ok. I think it's coming from the garage opener motor.
I changed the LED bulbs back to incandescent since sometimes LED causes these noises. Didn't help.
I read somewhere that garage opener circuit board problems can cause this symptom. But, other than the clicking noise when entering the garage and light coming on (motion sensor), the opener works just fine.
So, still no firm answer.
