gordonf238
- Gordon
- Aug 26, 2021
- NYC
- Mach-E AWD, Ext. range
So the other day, just for sh*ts and giggles, I wanted to see if MME would charge on gas.
I have a Ryobi gasoline generator in my garage which I seldom use. It has a 220V 30A outlet. Now unfortunately, the Ford mobile charger that comes with the MME will only work on a 50A circuit or higher, so no bueno. Luckily, I also have a Tesla mobile charger, which comes with a variety of power connections, and DOES work on anything from 120V -> 220V, (30A and 50A). Thank you Tesla, and Ford - you should be integrating this flexibility into your mobile charger as well.
With that said, once the generator was powered-up, I connected the Tesla mobile charger into the generator's 220V 30A outlet. Now, this being a Tesla mobile charger, the plug wouldn't actually connect to our MME. This is where the Tesla -> CCS adapter comes in handy. Not just for my little experiment, but anytime you're left stranded, and the only charger nearby is a Tesla one.
So on those occasions when power does go out, and you need to charge your MME using a gasoline generator, the process does in fact work. If I had purchased a more powerful generator, it probably would have offered a 220V 50A plug, making this process relatively simpler.
However, make no mistake about it - this is an utterly wasteful (and loud) way of charging your MME. Still, if and when the need arises, the possibility is there. I was able to charge at a 24-amp rate (toughly 12 miles/hr) while annoying the heck out of my neighbors.
Items used:
Ryobi generator Model #RY906500S
NEMA L14-30P to 10-30R 240V 30 Amp adapter
Tesla Mobile Connector
Lectron - Tesla to J1772 Adapter
Cheers
Items used:
Cheers
