Mach-e4x
- Steve
- Sep 2, 2021
- Oneonta, NY USA
- 2021 Mustang Mach-e 4x, 2016 Mazda CX5
- Retired
Actually, L engages maximum regeneration like Unbridled OPD.I took my MME out last night; the local roads had a fresh cover of snow and were pretty icy as well (Ohio State was in town to play Michigan, and I think the local road crews must have been watching the game instead of salting the roads ).
I definitely experienced the shock of 1-Pedal driving on slick roads. The first few times I took my foot off the accelerator, the car started to slide/slip and the and the traction control systems started taking over. I was a bit spooked by that, and I disengaged 1-Pedal. However, I wasn't happy with that either, as the brakes are fairly 'grabby'. The next time I go out I'm going to try to leave 1-Pedal off and engage the "L" mode on the drive selector knob. If I recall, that's a 'tamer' version of 1-Pedal and hopefully that will work as a good substitute for 1-Pedal on wintry roads.
In this situation, youād be better off just turning off 1PD and using the break pedal to engage regen when you want it.The next time I go out I'm going to try to leave 1-Pedal off and engage the "L" mode on the drive selector knob. If I recall, that's a 'tamer' version of 1-Pedal and hopefully that will work as a good substitute for 1-Pedal on wintry roads.
Can't disagree more. I don't ever use the break pedal on any vehicle... ?In this situation, youād be better off just turning off 1PD and using the break pedal to engage regen when you want it.
What's that white stuff? S-N-O-W? Never heard of it.
You forgot foulPedal
Brake
