DrAchoo
- Jason
- Aug 17, 2021
- Oregon
- Premium Rapid Red RWD, St. Batt Mach E
I'm getting ready to take a 300 mile trip to Seattle so I thought I'd work the kinks out of how to charge on the road by using a local EA station. Some notes and questions:
1) Wow. The length of the charging cord was short! I had to move my car three times and then inch as close as I could to the charging station to get it to plug in. Are there better techniques? I was generally following the painted lines on the asphalt, but it seems the better move would have been to park two feet to the right so the charging port is directly in front of the charging station cord.
2) I have a RWD, st. battery setup so I can expect up to 110 kw/h charging, correct? This station has good reviews on Plugshare, but I was pulling 35 kw/h for the 14 minutes I used it to go from 64-75%. I'm assuming I did nothing wrong. Is it just how fast the hamsters decided to run that day? Was it because it was a short charge? because it was starting from a relatively low battery discharge state? (EDIT: I'm reading other reviews of this station and they are saying they were getting about 40 kw/h on their charges. Perhaps it's the charger.) When you charge, how long before you get a good feel for how fast you are going to be drawing power?
3) The cost was $0.43/kw. I was using the Ford Pass and had free credits so it didn't cost anything, but in the future, will I be charged at the higher rate reported on EA chargers or on the "member" rate?
4) I've read a few "etiquette" guides and wondered if people really do leave notes if they step away from the car?
Thanks for the help!
