Murse-In-Airy
- Rod
- Mar 5, 2021
- Chaumont, NY
- Mach-E ER AWD
- Nurse
Hit the road for Southern NY today. After a whole week of working on the car, no way was I taking the company rental.
Left home at 77° and 100% SOC with GOM showing 230 miles for a 266 miles drive. ABRP said to stop in Albany and add 25%.
Well the first 80 miles was county 2 lane road. I averaged 3.5 miles/kWh with the cruise set at 60 MPH. Then I hit the highway and bumped it to 72 MPH.
When I got to Albany I was still showing 40% battery with 165 miles down and 100 miles left to go. Doing my math showed that if 165 miles took 60% of my battery then 100% should get me 275 miles. I’m that guy, so I bypassed the Albany EA charger and pushed on.
As I got closer to my destination it looked like I might come up just a couple miles short. So I figured to grab a few extra percent while I took a much needed bladder break. The pull off showed an EVConnect 60kw charger. Sounds good. Pull in. Plug in. “Overcurrent error”. Retry. Same. Call EVConnect. They can’t change anything. Well, I’m at 9% with 24 miles of range to go and 30 miles to my destination. But the next travel stop is only 22 miles away.
PlugShare says it’s currently occupied but that may be my best bet. Back on the highway.
I arrive at the next travel stop to find the EV connect station there isn’t occupied and it works flawlessly. It’s only 60kw but I’m at 1% with 2 miles of range on the GOM. I’ll take it. I pulled 9kwh in 13 minutes for $2.37. I only had 6 miles to go for the charger I really wanted anyway. So I’m off with 11% battery and 26 miles of range. ??
Stopped and grabbed a burger and hit the EA Charger at Walmart in Newburgh. P&C worked perfectly. Started at 123 KW and ramped down. Took 43 minutes to get from 7% to 80%. Gave me time to eat my burger and give the car a wipe down to get rid of the bugs. So I’m off to the hotel for some sleep with 80% charge, 217 miles on the GOM and I’ll be able to hit 100% on shift tomorrow from a 110 V socket at work tomorrow before I head home on Monday.
I gambled a little, but the stripes pulled me through. It’s been a good day.
