jlauro
Owosso, MI
The efficiency numbers shown on the ford.no builder are puzzling.
On the RWD, the standard battery range is 10 km lower than originally estimated in November, while the RWD long range battery provides 10 more km than originally expected. For the AWD, the standard battery loses 20 km range from what was anticipated, while the long range battery remains as predicted.
The RWD SR vehicle consumes more kWh per 100 km travelled (WLTP) than the heavier long range battery vehicle? How can that be right? The same sort of difference is shown for AWD SR versus AWD ER.
Am I reading this wrong?
Don't know if you are reading it wrong or not (I'm not looking at the numbers), but my guess is a fixed size buffer between the two batteries, so the smaller battery the buffer takes a larger %.
MY21 J1 Premium RWD SR
The reserved battery is about the same between SR and ER (as a percentage of the whole). And here in the order screens, they are showing overall battery capacity instead of usable capacity. So that doesn't explain the updated numbers.
Here are screen shots of the numbers I'm looking at... Notice how Norway's numbers have been updated (since they've recently announced certain test results updates, and are taking real orders now), while the Dutch text for the Netherlands hasn't been updated:
Ford Mustang Mach-E Ford Announces RWD WLTP Range Increase, Norwegian Orders Starting September 17th 1600443573713
Ford Mustang Mach-E Ford Announces RWD WLTP Range Increase, Norwegian Orders Starting September 17th 1600443593931
jlauro
Owosso, MI
Are you certain about that?
If I run the numbers with a 20% reserve of the SR, and then use that same reserve (15.2) on the ER then the distance matches after scaling (rounding to 2 significant digits). (That would mean a 15.35% buffer on the ER and 20% on SR)
Zandje
Netherlands
VW Passat GTE, MME AWD TP+ Lucid Red (2021)
And the AWD SR adjusted to 400KM. That is a bit disapointing...
AWD ER to 540KM.
Marcel
The Netherlands
Woodworker
This can't be correct 17,5kWh/100km for the standard range (lighter) and 16,5kWh/100km for the long range (heavy) same car only ?150kg? Weight difference
jlauro
Owosso, MI
AWD ER to 540KM.
540km = 335.5 miles, which would be great, if EPA... will be disappointed if those come out lower than originally planned.
jlauro
Owosso, MI
Shows 17,2 (not that it's much better than 17.5). I am guess it's because they have same size reserve/buffer instead of increasing the reserve with the larger battery. That said, the buffer shouldn't count toward to kWh/100km, but it would explain the max range difference.
timbop
Ford already published the reserves: the 99kwh ER has an 11kwh reserve (11%), and the 75.7kwh SR has a 7.7kwh reserve (10%). So, almost exactly the same percentage, but different kwh values.
jlauro
Owosso, MI
I don't think those were declared final when published (and who is to say they are the same over all regions... they could adjust that based on climate). That said, it does seem strange that the ER would have a larger by %....?
timbop
I dunno. Maybe the guy that wrote the software likes integers, or the 88kwh and 68kwh are rounded-off figures because they don't want to say 67.373kwh. Either way it feels like a distinction without a difference. It seems like they're close enough to call them effectively the same in practical terms.
jlauro
Owosso, MI
Yes, they probably like iteger / 2 significant digits. If you go by the base numbers and calculate useable both assuming 10% buffer they come up with the numbers posted at https://www.ford.com/buy-site-wide-content/overlays/mach-e-overlays/mach-e-faq/ which makes more sense then ER having 11% and SR having 10%.
Marcel
The Netherlands
Woodworker
What they did is calculate, battery size devided by energy consumption that's why it is wrong
Energy consumption per 100km isn't impacted by battery reserve.
I just find it puzzling that Ford's standard battery configuration is less efficient than the 400 lb heavier extended range configuration. Especially on the RWD trim, where the available battery power exceeds the single motor's power limit in both battery sizes.
Maybe they put the numbers backwards on the web site?
dbsb3233
TimCO
Colorado, USA
Yeah, just sounding like a mistake. I'd ignore it.
Shayne
Northern Ontario Canada
2021 MME4x Prem
1. Companies "self-certify". Run the tests, send the results to EPA.
2. EPA can elect to audit anyone's vehicle and test results, i.e. take the same test vehicle the company used to get its test results, and run it themselves to make sure they are not pulling a "VW diesel". You're gonna have to trust Ford on this one, since the EPA Ann Arbor lab is still basically "COVID closed".
3. I anticipate you will be completely unsurprised by the final EPA range numbers.
What does 3 mean that; the 88 kwh will produce 270 mile (430 km) epa range in an AWD like estimated? I was leaning for 450 km and a small increase; guess now that will be surprising.
I thought that
NEDC minus 17% for real world
WLTP minus 8% for real world
EPA minus 2% for real world
was a rule of thumb. That places EPA at about a 6% difference but does not line up with the estimated EPA unless there are different batteries 600 (375 mi) x 0.94 = 564 km 352 miles does not line up with an EPA of 300 miles? Different packs for Europe?
EDIT: 600 x 0.94 x 88/100 kwh = 500 km 310 mi?
