Billyk24
- William
- Nov 29, 2019
- PA
- Ford C-Max Energi, Premium Mach-E ordered
This reply is not making sense. Battery size does not make a difference. The on Board charge does and both the Model 3 and Mach E have the same capacity at 11.5kWh. The Mach E has a larger HVB size so it will take longer to "fill up" but will charge at the same range under the same conditions at a level 2 charger.So just because the car accepts the same amount of power doesn’t mean that it generates the same mileage per unit electricity. The 32A on the Mach-E generates around 22mi of range per hour, since the 99kW battery is 300miles of range.
If the Mach-E had the same size battery as the Model 3 then yes it would be 30.
