Advertisement
timbop
2015 Mustang Convertible, 2016 Dodge Durango
Great info... Looks like there are differences from the US models. If the range is indeed in miles, that would be an improvement, but in line with my thinking given weight and size of the battery for the ER AWD.
The UK uses WLTP for rating mileage, which generates higher range numbers than EPA's method here in the states. It is generally accepted that the WLTP numbers are high, and the EPA a little low from reality
portlandg
grahame
uk
grahame
kuga st line x RWD ER MACH E on order
Cabinet maker
So hopefully we should be able to get about 320 to 330 miles range . I could live with that
LYTMCQ
Lyt
Portland
Lyt
Telsa Model 3 LR AWD
LR RWD is rated 300 miles EPA so I would expect that range at best. EPA testing does not include the heat which is free on ICE cars and energy costly on EV's. Tesla's heater is 4kw and will use 16 miles of range per hour of driving if on full, likely 8-10 in regular cool weather driving.
Cooler weather, 50F and less, is going to start impacting range via the battery capacity so that will also lower actual range.
And then, regular charging is 10%-85% so working range of 75% on day to day, 225 day to day. On road trips, charging that last 15% is a slow process so you will likely be using the 225 on trips to get fast charging when you do stop. Than deduct the heat as needed. Then deduct the battery capacity as it gets colder.
And then battery degradation over time, 5% 1st year, 10% by 2nd year is not uncommon.
It's best to approach the range conservatively especially if one is doing a lot of miles a year and longer trips.
Wonky_Donkey
Tony
UK
Tony
2019 Prius PHEV
...all very true, but also it comes down to individual driving style, the types of journeys you do, and the speeds that you can drive at.
So actually EPA / WLTP is all just a best guess - a finger in the wind to be able to compare vehicles on the same potentially unrealistic set of rules - it gives you a rough idea, and no more.
One of the many reasons why WLTP figures are higher for Europe / UK is that we don't spend anything like the proportion of US journeys on fast roads. A large amount of our road infrastructure is old and slow (but conversely more efficient to drive on)
The only true way you will find out what range you will get in a Mach-E is to buy one and drive it in your country, on your roads, in your climate, with you behind the wheel.
LYTMCQ
Lyt
Portland
Lyt
EPA is spot on for ICE vehicles. Usually you can beat EPA numbers. EVs have issues that EPA does not really measure, heat, higher losses than ICE at higher speed, temp effect on battery/range, the 75% rule and battery degradation over time. You don't see a 5% deration on an ICE vehicle mileage in first year or second year.
It comes down to individual driving style, the types of journeys you do, and the speeds that you can drive at.
Always but the deration for EV's is more in day to day use and the charging on the road adds a lot of time so you need to go in with all the practical facts.
Single biggest surprise with new Tesla owners is range, range, range and Tesla's have tops range.
Drove to Everett WA on Friday, 196 one way, 392 round trip. I had to charge for 30 minutes three times in an ostensibly 310 rated car. That would have been two charges for someone with home charging but the "book" would have said one 20 minute charge.
That kind of higher "maintenance" plays out every day.
EVer
California USA
Model 3P, F150
"higher losses than ICE at higher speed "
This isn't so. Both experience an exponential increase in drag. Most ICE-powered cars have multi-gear transmissions. while most BEV cars do not. That is the primary factor, not the energy source.
LYTMCQ
Lyt
Portland
Lyt
Which is why it is so. Porsche has a two gear setup in the Taycan which is why most Porsche owners are seeing 240 mile real world range vs. EPA 200.
Wonky_Donkey
Tony
UK
Tony
2019 Prius PHEV
@LYTMCQ - let’s not forget that according to WhatCar’s comparison of EPA vs Manufacturers - the Elon buggy’s have the greatest deviation between quoted and actual range.
That may be why your experience has not been great at obtaining the quoted figures.;)
EVer
California USA
Model 3P, F150
"Porsche has a two gear setup in the Taycan which is why most Porsche owners are seeing 240 mile real world range vs. EPA 200. "
It isn't as if they disabled the second gear during testing. You make no sense.
LYTMCQ
Lyt
Portland
Lyt
EPA has four high speed tests, three are at 60mph top and one has short top speed of 80 mph so the Porsche high gear would tend to get de-emphasized.
"The gearing step is large, with the second-gear ratio roughly half of the first and the shift point happening around 50 mph. In most driving, the Taycan runs in top gear. First-gear starts happen in Sport or Sport Plus mode; to do it in Normal, you'll need a large accelerator input."
So the 2nd gear is big jump and doesn't start until 50 mph so Taycan's range gets understated above 50 mph and owners are seeing the 240 in real world driving.
Yoliber
Irvine, CA
TM3 SR+
I'm seeing a big deviation with my model 3 as well. How do Tesla's get away with having such a high EPA rated range? Porsche was rated at 200 miles EPA but 280 miles WLTP. Reviewers are able to get 240-300 miles easy.
I recall Ford saying that the range miles are going to be conservative. Have we heard otherwise? I'd hate to be disappointed again.
KAustin
WDC
Kia Telluride
Not yet.
dbsb3233
Colorado, USA
2013 Ford Escape
EPA is so deceiving because even though they hit high speed some in the tests, it gets swallowed up by all the lower speeds averaged in. While they publish an MPGe "highway" number, I think it only averages something like 46 MPH.
And frankly, almost no one even looks at MPGe numbers. For BEVs they look at RANGE. And that's based on an even lower-speed city/highway combo. Which is often WAY off for where range actually matters: high speed road tripping.
dbsb3233
Colorado, USA
2013 Ford Escape
I wouldn't expect anything major though. Most clues point to a modest EPA range increase (like 3-5%) in range.
Advertisement
