tannerk89
Tanner
Roanoke, VA
Mach-E P4X
Project Manager
I really appreciate how willing Farley is to change things very vocally. It gives me a lot of confidence that Ford has what it takes to survive and thrive through the disruption in the industry despite the initial pains from making the shift.
jhalkias
2021 RR ME FE, 2016 Escape, 2019 Fusion Energi
Benefit Fund Administrator
Good move.
At a minimum, Model E Elite dealers will need to install two high-powered DC fast chargers and a level 2 charging station, as well as offer at least one DC fast charger available for the public to use...Model E Certified dealers are only required to install one DC fast charger, and it must be made available for public use.
This won't help in many cities where dealers are located and infrastructure is already going in but will be a big improvement to charging infrastructure in rural areas.
I hope Ford adds up-time requirements on those chargers.
sotek2345
Tom
Upstate NY
Engineering Manager
Or a charging rate requirement. 25kW still counts as "high powered".
That said, I am not sure I would want to spend time waiting at a dealer while I charge, but I suppose any port in a storm if you need it.
jrstinkfish
Scott
Memphis, TN
2021 Mach-E Premium RWD SR Infinite Blue
Yeah, it can be a lifesaver -- I was transporting my new Bolt from Nashville to Memphis, and the Nissan dealership in between that had an L2 charger really saved my bacon when I knew I'd need 20-30 additional miles to make it home (I think I made it home with about 20 miles to spare!). I sat there in my car and read the owner's manual while I waited 😄 Fun times!
Guss-E 2021
Guss-E 2021
New Hampshire
2022 Mach-E Prem AWD ER
My family has a camp in very rural Concord, VT. There is nothing up there for DCFC. Well except for a Ford dealership 9 miles away. Brand new Chargepoint 62kW chargers. Took me longer to drive there and back than it took to add the miles I needed. Yes, a bit out of the way but better than no option and the drive over is gorgeous 😊
Billyk24
William
PA
Maybe! One can read on plugshare of rural locations that are greeted with a $1000 a month demand charges for installing dcfc. The grid system needs upgrading and capacity needs to be boostded.
DanHo
Seattle
21 MME RR 4x & 17 Toyota Tundra
Level 2 charging should be required at all dealerships with at least one 14-50 outlet. My reasoning - my ME would stop charging about 10 minutes into the charge. I didn't think it was the mobile charger because it never showed a fault and it wasn't my breaker tripping. Ended up taking the car and the mobile charger to the dealership. They said they had no way to test the charger (they have hardwired level 2). Thankfully the issue was fixed with a software update and clearing some faults. They basically told me that if I was still having the issue I would need to bring it back.
Blue highway
Oregon
Mach E Premium SR RWD
For the next 5 years or so, there will be no such thing as enough DCFC infrastructure. The ratio of cars to chargers is going in the wrong direction really fast at the moment.
dbsb3233
TimCO
Colorado, USA
2021 Mustang Mach-E FE Red, 2013 Escape Titanium
Seriously?? Requiring DCFC at dealerships is stupid, unless they feel it's necessary internally (service dept testing).
This is a good way to get dealers NOT to become EV certified. At least if the requirement is for high power DCFC. If it's just 25kW or something, that's probably not wildly expensive.
dbsb3233
TimCO
Colorado, USA
All the more reason we should discourage DCFC and encourage L2 charging overnight where people sleep. At the lowest demand period of the day where it's actually good for the grid (as a demand leveler).
There certainly needs to be DCFC for travelers and other rare situations, but otherwise it should be heavily discouraged. Probably the best way to do that is to jack the prices up (and stop with any free DCFC). Make it highly compelling to L2 instead of DCFC.
There are more than a couple of locations where Ford is going to have to be flexible with these rules or face having no ev dealer at all. Electric grid Infrastructure isn’t the same everywhere. What works in suburban California often won’t work at all in other areas. One size does not fit all and I’m reasonably certain Ford does not want to strand its 2023 and earlier ev customers.
timbop
2021 Mach-E (CA RT1), 2022 Lincoln Corsair PHEV
Or the FEE STRUCTURES need to be changed. It seems odd that utilities are getting net metering thrown out so they can buy electricity from home solar at wholesale rates, but then resell that electricity at exorbitant terms with demand charges. 🤔
Absolutely. If Ford isn't careful they will cut their own throats. I said it in the other thread, but it seems ludicrous that Ford wants to have the benefit of a nationwide charging network without making any investment. This is going to backfire on them either from losing initial sales or when their network has poor coverage due to too few chargers at too slow of a speed with poor maintenance.
From my own parochial point of view, this has the potential to blow up. I know the local dealer was not happy with the cost of two commercial L2 installations at two locations. Everything is several magnitudes more expensive out here. I’d be surprised if both of the dealers locations could support the required DCFC. Both locales could certainly use it as the Greenlots stations are beyond bad here.
Anyway, we shall see what happens on the Orchid Isle in a few months.
