Fixbear
- Frank
- Jun 15, 2022
- ADK. foothills, NY
- 2001 SelectMachE4 SR , Mini SE
- retired, Construction Mechanic, Refrigeration tech, Ford, GMC, Chevy tech,
Wire gauge is no more than diameter of the wire. There are several different cable designs for their use. Even different in the same spec. Like THHN can be solid or stranded. Flexible cables use a finer gauge wire and more conductors in the sheath. Take a common extension lead. It can be SJ, SJO, SO, MTW and on and on. The SO is more of an industrial cable and will be more robust and oil resistant due to the neoprene outer sheath. SJ is relatively smaller and lighter vinal sheath. The cables have to be spec'd for their designed usage. Like MSC is made to be run over and survive in a mine. Tough stuff, but very expensive. Has thermoplastic wire bedding cut resistant under the outer sheath and 3 GFI tracers. But because of that, it has a reduced bend radius.Ok, I'll just forget about everything I know as an electrician, then. Enjoy damaging your charging cable as much as you want, after comparing a heavy gauge #6 AWG (like for your stove) set of conductors to a #20 AWG pair of stereo wires. Do how you want.
The type of wire and the number of conductors in the cable also determine the current carrying capacity
