Ford Warranty Guide 20201
Florida7382
Mustang
Has anyone been able to locate this? I have found and read the 2020 version but am not sure if Mach-E will fall under it as it’s not very specific on EV topics. So, assuming 2021 version will cover Mach-E.
Florida7382
Mustang
thank you. I’m however looking for the actual guide as I need to specify if the vehicle will keep its warranty if imported to Europe at a later stage. Assuming there will be recalls and issues as it’s first year model + the battery warranty is long so I want to take advantage of that.
RyZt
San Jose
Mach E4X
Be aware that charging ports in North America and in Europe are different. NA uses CCS Type 1 whereas Europe uses CCS Type 2. Type 2 has one more pin because AC in Europe is three-phase. The shape of the connector is also different (that it's impossible to plug one into the other)
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
What does
what does focus warranty Policy say about exporting/international warranty?
Don't know: Never read it that in-depth to find out.
Florida7382
Mustang
Well aware, thank you. It’ll require an adapter and charing is limited to 7.2kW in practice (non DC). 20k cost difference however will help to deal with these inconveniences.
