FordPass 3.25 released
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
Ford Mustang Mach-E FordPass 3.25 released Screenshot_20210630-164514_Google Play Store
benk016
benk016
Ben
Tulsa, Oklahoma
This is the only difference I've noticed so far on Android
Ford Mustang Mach-E FordPass 3.25 released Screenshot_20210630-164929_FordPass
MY21 J1 Premium RWD SR
The pages are loading faster for me so far.
The More screen lists app catalog right away now instead of popping into the middle of the list after a second or so.
The home screen and vehicle pages are loading faster but still not very good (elements still move around while it loads and it still interprets a drag as a tap plus a drag).
JCHLi
The font for "enabled" for Paak changed.
benk016
benk016
Ben
Tulsa, Oklahoma
Mine had the app catalog pop in once after the update. But since that time it hasn't done it since. Even forced quit and reopened and it was there immediately.
Ok serious (enough) comment. Mine auto updated yesterday. What I noted difference wise for the Apple version is:
1. Battery drain is back big time. 2 hours and change of driving today and I went through about 65% of the battery.
2. PAAK went from working almost all the time to almost non-functional. Locked out of the car 3 times where I had to use the door code. With Bluetooth connected.
3. Software update status is incorrect. FordPass shows it as set to manual. It’s not, it’s automatic and has been since I got the car.
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
Machine Control Specialist
Maybe they're trying to make a point. "See what happens when we push out an update too quickly without adequate testing?? Imagine if this was an OTA for your car." ??
woody
CO
Mustang Mach E, Chevy Bolt
Same with android.
Wasted an hour trying to figure it out to no avail.
metalpro2021
Amsterdam
Mach-e 1st edition
Software architect
Some other noise : since the release of the APP (couple of weeks ago in The Netherlands , EU) my battery (Samsung S20+) drain HAS STOPPED and PAAK is MORE reliable.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Refreshes just about as often. Installed and still did not. RIP Fordpass server.
1. Is this with 3.25 or 24? It appeared twice for me on 24 . Driving and setting up paak again. Not fixed on 25 thanks for the info.
2. You had it a while now it is getting to the confused stage. ;)
3. When I got it back from the shop this last time and all working fairly well I tabbed off auto-updates. I was wondering this and would have known in a bit. Hard to know if you have stability (or it gets confused) if it keeps changing the game. Force feed updates at this stage?
Looks like the shoe is on the other foot for a bit. Me I think my hardware is good now and hope OTA fixes the rest. All working fairly well for me at this stage.
In the UK we have V3.23.0
If you go to the app store and search and tab the page for fordpass info it sometimes shows an update even thou it was not flagged or auto-installed.
rodhx
Rod
Alabama
Rivian R1T, Lexus IS300 autox/track car.
To the best of my knowledge the app has never correctly shown my car's software update status. This has been the case for at least the last three app versions. Not a big deal but it did make me confirm the car's setting the first time I noticed the app error.
edit: until immediately after making this post. Now 3.25 shows it set to "auto" ?‍♂
3.25
All the comments are to 3.25. It was pretty much fine until that update to FordPass. I also don’t generally have FordPass running though unless I’m using the car or will be shortly.
