tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Software Developer/System Admin
FordPass Scriptable Widget v2022.02.18.0
Description:
Many months ago I found a FordPass widget while searching for some Ford pass API stuff.
I've completely refactored the entire script and turned it into an alternative control to FordPass.
Feature Walkthrough Video:
What's New in V2:
  • New Widget Designs
  • Define widget types in widget settings as a parameter (this allows you to have multiple versions of the same widget. If you don't define a color mode it will use the system dark mode setting.
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
  • Quick action buttons on some of the widgets.
  • Modified the fuel/battery to embed the icon in the bar itself.
  • New dashboard app that opens in scriptable for info and controls
  • Push notifications for the following:
    • Widget updates
    • Deep Sleep Mode
    • Low 12V Battery (off by default)
    • Firmware Updates
  • Lots and lots of bug fixes.
Download and Instructions:
https://github.com/tonesto7/fordpass-scriptable
Ford Widget Tool Installer (tonesto7.github.io)
Updating from v1:
Please install the latest widget tool
Latest Release Announcement:
Reporting Issues and Feature Requests:
Please open up issues or feature requests here https://github.com/tonesto7/fordpass-scriptable/issues
If you are a coder yourself please submit pull requests and I will gladly merge them if they make sense.
Giving Thanks:
Thanks again to dschablowsky for all his work on the original script which gave me the ambition to make this beast of a widget.
Logal727
C
Hmm I have the new script installed and added to homescreen and have it selected under Edit Widget but the widget just looks like the default scriptable widget
Logal727
C
Hmm, I can get the medium widget to work but not the Large one, weird
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
The large widget is a PIA!!! It randomly doesn't want to reload
atomdeathstroke
Atom
Milwaukee WI
2021 Ford Mache E Premium
I make stickers
Works great!!! Thanks for the awesome work!
also, look at that battery…. Nice.
Goober96
Brent
SC
2021 Mach-E4X, 1996 Mustang Cobra, 2008 Corvette
Can you put the odometer on the detailed view? Looks like this detail was left off. :) Great widget by the way!
smartino
Indiana
2021 RR Mach E First Edition, 2017 Honda Ridgeline
I can’t get the large widget to display. The small and medium ones work fine. If I put the large and medium widgets on the same page. Then neither will display the information. Something about the large widget causes issues.
I have an iPhone 13 Pro Max.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
Ok. I’ve thus far avoided all the widget stuff. But this thing is beautiful. I may have to dive in. Amazing job @tonesto7 Thanks for sharing your hard work.
If I had any useful skills, I’d offer them as payment in kind. But….
DoeringItRight
Western New York
2021 Mach-E Premium AWD Extended Range
Wow this is awesome! Just set up the simple medium sized one to test it out real fast & it’s better than the ford app lol
Great work & thank you for doing this and making it public @tonesto7
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
The large is very unpredictable currently. If it doesn't work for you then avoid it for now. I will continue to see if I can find the cause.
