MyLittlePony2022
- William
- Jul 17, 2021
- SF Bay Area, California
- 2022 "Mach-E Auto" GTPE, Cyber Orange
I want to start out with a positive. I think the Sto-N-Sho is a very well-engineered bracket. It mounts without any issues; no drilling and the quality of the product is great. I did not have any issues with the sensors. Recommended, with a caveat.
There are two areas that made me change my mind and remove it from the car. The very thing that makes it easy and non-destructive mounting, is also an issue. The single bolt and just 3M tape, results in it not having a solid mount. If the tape come loose, it tends to wobble on the single bolt. Not a deal breaker for me since I just drilled two more support hole and mounted it on the underside of the front spoiler. Not worried about two small holes.
The biggest disadvantage is that is it is lower than the front spoiler. I try not to have the spoiler come close to the parking stops or curbs, but it is and will happen. Some on the forum may be exception drivers and do not get their front end close to curbs, I have not had that skill or luck. The first time was a minor issue, and I bent the front plate. The second time bent the bracket and plate and the whole thing was just hanging down (not drivable). Below is what happens when a 3-ton car pins the plate and bracket on top of a curb and then drags it across it, as the car backs up. I can fix this, but it is going to happen again, and I do not want it to take place when my wife is driving the car. I was there and I had to take the bracket off in a parking lot.
I knew ahead of time, when I ordered the bracket, that it was lower than the spoiler. My fault and I took the risk. The had vinyl as a backup plan. I was optimistic. I just ordered the vinyl license plate, since it is legal here in CA. I think the real plate looks much better than the vinyl. I will look at Craig's bracket and the EOS but the wife says the look ugly and she keeps hitting the plate when she walks by (small and tight garage).
