Great e-heat tip from YouTube (Nick Amstrong)
SashaLondon
Sasha
London
MME AWD SR
This video looks at the e-heat and does some testing with a laser thermometer. You can watch the video but my takeaway was that to get the hot air coming out he switched on the re-circulate button. This noticeably increased the temperature coming out the vent. Sometimes the heating is very weak and this is a good way of beefing it up. I haven't had a chance to test this out in the car yet.
Yes, which makes perfect sense since the source air doesn't have to be heated as much. This adds to the frustration that the recirculate setting won't stay enabled for more than a few minutes.
While it has not impacted me directly since temperatures in my area are pretty moderate, we do get some days when it goes well below freezing. I cannot believe the behavior of the recirculate function was intentional. So hopefully this will get fixed in a future update.
Unfortunately, it appears that it was intentional. But, hopefully, they will update the software at some point to make it a little less aggressive.
Ford Mustang Mach-E Great e-heat tip from YouTube (Nick Amstrong) 1641563714262
I thought this was pretty common knowledge. I was under the impression that this is how normal vehicles have operated.
It is. But the difference is more obvious in the MME than in ICE cars because the power of the heat source is more limited.
SashaLondon
SashaLondon
Sasha
London
MME AWD SR
Yes, but in ICE cars the heating can be so much hotter so it doesn't matter as much.
DR.J56
Great info but that was agony. Could have summed that one up in 2 or 3 minutes. Yet, I watched it, kinda.
Shayne
Northern Ontario Canada
2021 MME4x Prem
That is what happened to me last winter I would switch it on only to find the car resets it a short time later. I just gave up on it and use the seats more for adjustment. Guess the car is smarter than us and knows when our windshields are fogging up when we do not? It is happening you just do not see it ;)
nvabill
Virginia Beach, Va.
F-150, '22 California Route 1
This is common knowledge in most cars, or at least I thought most people knew about it, turn on recirculating in either hot or cold weather. This way the air has already been heated or cooled somewhat before being pumped through the system versus bringing in fresh hot or cold air.
nvabill
Virginia Beach, Va.
Gotta make that money on YouTube by having people watch as long as possible. ?
I wonder what would happen if you put it on Max A/C and at 67 degrees when it is 10 degrees F outside? Would that keep recirculate on, keep the windows from fogging, and provide more heat? One day I will try it.
Chudsaviet
Timofei
Bothell, WA
Software
Come on, what an invention!
Heating already warm air will give you warmer air, unbelievable!
Actually, keep in mind that CO2 will raise fast in a sealed vehicle, don't use recirculation for too long.
sockmeister
Pennsylvania
2021 Mustang Mach-E4x
SW Engineer
Not enough to matter -- Car isn't airtight. If it was, the blower wouldn't be able to work when it was not on recirculate, at all.
This nanny feature of locking us out of recirc after 10 minutes is really frustrating. At the very least, give us the option to toggle such a nanny feature on or off.
