DevSecOps
- Todd
- Sep 22, 2021
- Sacramento, CA
- '21 Audi SQ5 / '23 Rivian R1T / '23 M3P
- CISO
First of all, I have @horsiedad to thank 100% for this idea as I got the idea from him and I have to credit the original creator of the idea @dtbaker61 and his post here. I didn't know that @dtbaker61 had originally done this. My way was different than his so credits to him, but here's a different take at the same thing.
The jump point access to the MME is ridiculously troublesome to get to... It's not hard to get to it, but it's not something you want to do when you need access to it. It requires the removal of a couple plastic trim pieces in the frunk. If you're unlucky enough like me you'll break the clip on the trim piece and swear at Ford for 30 minutes straight.
So let's get into to it (Click on pictures to expand them):
Step 1 - Remove the plastic trim pieces. This starts with the plastic trim piece along the upper part of the Frunk where the windshield is. Then remove the plastic trim on the right hand side of the Frunk where the + and - are imprinted into the plastic.
Try not to break the plastic clip like I did, which I had to JB Weld back on.
Step 2 - Mark the location of the pilot holes on the underside of the right hand trim piece and then drill them with a small drill bit.
Step 3 - Turn the trim piece over and drill 2" holes where the pilots are located with a hole saw
Step 4 - Ream the holes. I used a ream tool for copper pipe which works really well.
Step 5 - Cut the stabilizer tabs in the back at the negiative jump point. You have to cut these back a bit because they will interfere with the plug and prevent it from grabbing if you don't.
Step 6 - Sand the holes. I used a 150 grit and followed it with a wet 1000.
Step 7 - Put the car back together and put the plugs in! The plugs can be obtained from Amazon. Just search for 2" plugs. Make sure you get some that will work on 1/8" thick plastic.
NOTE: A note for anyone who got this far. There are templates provided in this thread from other users. The difference between the two methods (mine vs theirs) is the following. You can decide which method you prefer.
My Method: Holes are located directly above the jump points. The center of the hole is center with the jump points. This means that the + icon is sacrificed.
Other Method: Holes are offset and are not centered on the jump points. Both the - and + icons are spared.
- The ground pole is located along side the second stabilizer. Holding your drill bit along the stabilizer 3/8" from the lower edge is where to drill the pilot hole
- The positive point is located 7/16" above the centerline of the clip in the below picture and 2 1/2" from the centerline moving towards the center of the trim.
