Thanks for the update! Setup looks much improved with the extender. Doesn't look too far out at all and the fact that you can open the hatch is a bonus. If you have time, so you mind sharing a close up photo of the extender in the Torkhitch itself? Thank you.Updates!
I received a Kuat Hi-Lo extension today - it is a beefy little piece, with a nice threaded hitch pin that secures the extension to the receiver at either the 7” or 10” extension position. It has a ~2” drop (or rise).
In the “drop” position, the fact that the EquipD rack has a slotted hitch pin hole, you can slide it deeper into the extension, meaning the “effective” extension is about 5.25”. In the “rise” position the extension interferes with the bumper and I think you’d be stuck with about 10” of effective extension (but with great ground clearance).
I have half a mind to drill some new holes and put in a new sliding hitch pin nut to allow the extension to mount sideways, but haven’t committed to that yet.
The punchline is that things look good in the ”drop” position, with everything slid as far in as possible. The lowest part of the rack is still 8” above ground. Departure angle isn’t phenomenal, but I’m generally comfortable with it. The rack is basically 5” further out, and 2” down. It sticks out a bit more, but doesn’t look ridiculous. The EquipD’s slot lines up with the extension’s pin hole so it can be locked in place as designed.
A side benefit is that in this configuration the hatch can be opened and closed with the rack up! Nice benefit I wasn’t expecting.
The assembly is quite rigid. Naturally it will wobble a bit more with the extension than without, but the Kuat threaded pin is quite stout and holds things snug. There is a locking version of this pin sold by Kuat for $20, however it appears to be out of stock everywhere. I’ll upgrade when back in stock.
If I could still get a magic 3” extension instead of 5” I’d take it, but this is enough to work as a solution for me for now. It might be possible to use a little grinding with a flap wheel to nip a bit off of the bottom of the receiver collar to allow the rack to overlap the receiver a bit, but I’m going to ride with it this way for a bit and see how I feel.
Photos below:
Thank you. Looks great. Really helpful. I think I can move forward with this setup for sure now. ??Here are a few pics of the extender seated in the hitch itself.
Im also interested to see your bike on the back. I have to use XL frames so my YT Izzo with 29" wheels is really big. I'm curious to see how much coverage the back of the mach e provides. When it's on the back of my fusion it's like a parachute behind my car. I literally lose 10mpg on the highway with my bike on the back.
Nice yeti, pretty much looks the same size as my XL size Izzo with the wheels off the side of the car and bars over the roof. When you're on the highway do you find the bike is moving a lot at 70+mph? On my wife's old rogue that she had it was ok, but on my fusion (car vs suv though) it can really start to get crazy at highway speeds. Any kind of wind and I have to slow down to 55-60mph at the most.I use a straight 6" extender.... when I take the rack off, the hitch receiver is tucked under to minimize view.
solid as a rock at highway speed+Nice yeti, pretty much looks the same size as my XL size Izzo with the wheels off the side of the car and bars over the roof. When you're on the highway do you find the bike is moving a lot at 70+mph? On my wife's old rogue that she had it was ok, but on my fusion (car vs suv though) it can really start to get crazy at highway speeds. Any kind of wind and I have to slow down to 55-60mph at the most.
What straight 6" extender do you have? Hitch is on order and if I need an extension, probably don't need much. I'm looking for the shortest available. I'm only seeing 7" and greater when shopping around.I use a straight 6" extender.... when I take the rack off, the hitch receiver is tucked under to minimize view.
I think I just went down to the local Harbor freight... it was something like $20.What straight 6" extender do you have? Hitch is on order and if I need an extension, probably don't need much. I'm looking for the shortest available. I'm only seeing 7" and greater when shopping around.
i did not want the extender to result in less clearance as I go on some bumpy dirt roads for MTB trailheads sometimes...... I'd look for something straight, or goose-neck UP for more clearance.Thank you. Looks great. Really helpful. I think I can move forward with this setup for sure now. ??
Yeah this is my main concern with these extendersWhatever extender you get make sure it has a threaded hitch pin or other anti wobble device. If you use an extension meant for basic towing it will make your rack a lot less stable.
Is this a 'supported' add-on? Like would adding a hitch receiver break warranty?I just installed my Torklift Ecohitch, and my 1UP EquipD double bike rack. The fit is a little close for comfort. The hitch requests a minimum of 2" of insertion after the anti-wobble bearing, which doesn't work. At 1.5" of insertion, the rack is far enough out that it won't hit the car, but just barely. It is plenty far out with bikes on (even with 800mm bars), but in the closed position it is very snug. I'm sure they have a little safety factor in their 2" recommendation, but I don't love that I have to go out so far to get a solution that just barely fits. You can also tell that 1UP doesn't like this level of extension because the slot doesn't line up with the hitch pin hole, meaning it can't be locked to the vehicle like this.
I've ordered a Kuat Hi-Lo adapter, which gives up to 7" of extension, and 2" of rise or drop. Unlike straight-through adapters, however, it looks like in this case if I drop or raise the rack (probably drop), then I can probably slide the 1UP deeper, and get less than 7" of total extension. Ideally I'd have about 2-4" of extension. Dropping by 2" looks like it would be OK from a clearance perspective as long as you aren't on any really rough roads.
The hitch and rack themselves are great, both very high quality, I just wish the Torklift came with another 1-2" of extension, that would make it a perfect fit out of the box.
