- Greg
- Apr 20, 2020
- Phoenix
- 2021 Mach-E FE, 2021 Wrangler 4xe High Altitude
- Manager
According to the manual......the car will condition the battery even on 120v. It will supplement shore power with energy from the HVB when needed. Should be minimal so it won't really impact your day to day range too much. Give it a try. You should be fine.I will look into ventilating my garage, but that isn't going to happen in the next day or two (car is scheduled to arrive then - was an unplanned purchase when I started to have problems with my 2010 Subaru Outback). I'm really just concerned about keeping the battery pack sufficiently cool in my hot garage, hoping the 110v outlet will provide sufficient power for that task. From your answer above, it sounds like it won't. I'll give it a try and schedule EVSE installation if 110v isn't enough for cooling the battery (and look more closely at EVSE recommendations here).
I was hoping to put EVSE installation off for a bit because I'll be able to charge at my workplace in a covered ramp garage, as long as I get to work early enough to plug in. The ramp garage stays much cooler than parking a car under the South Florida sun, so alone is strong motivation for to get up earlier and get a parking spot there! And hopefully it will be cool enough to be safe to use the level 2 chargers at work during the day.
Thanks,
Elle
Many potted style mobile EVSEs (such as the one that ships with your car) may overheat when used in warm spaces that lack airflow or when left in direct sunlight. Make sure it's shady where you place the body of the EVSE and if possible, place a fan to keep it cool when charging. I can't imagine 120v causing too much heat but those things will usually trip the thermal limiters when charging at 240V in warm spaces.
