Ghost Ryder
- Sep 19, 2021
- LA
- Tesla MYP, 22 GTPE
I had PAAK set up since I got the car in March 22. It has worked well enough. However as of last week, it just disappeared.
I went on vacation for 2 weeks, so the car sat at home. It went into deep sleep. I'm not sure if it's related. When I got home from vacay, PAAK did not respond, so I used the door code and back up password. I didn't think anything of it as this happens with PAAK every so often. But when PAAK failed for a couple of days, I decided to trouble shoot it. One of the first thing I did was log out of the Ford Pass app. When I logged back in, PAAK was gone. It's like I've never set it up. There was a link on the APP that ask me to set up PAAK. However when I tried, it would fail to Download a digital Key. Tried multiple times, always the same results, "Key Download failed." I tried everything I could think of. I even reset the PAAK from the MME and erased blue tooth from the phone as well as delete all phone connections. Nothing helped.
Has anyone ran into this problem with "key download failed." I have a iphone 13pro.
I just found a solution to the "Key download failed." In my particular situaton.
You have to set your phone (not the car) to 24 hour mode. Then the download would go through.
Hope this helps others with this problem.
