GrumblesTheDog
- Aug 21, 2020
- Ohio
- 2021 Mustang Mach-E GB FE
Hi folks. I don't think I saw a dedicated thread for this, just individual posts about good battery management practices.
Does anyone have a sense of how much DC fast charging you'd need to do to result in noticeable battery degradation/capacity loss? I'm curious, since the MME has proven itself to be a very nice road-tripping car (and will be even moreso when BlueCruise launches) to the point that I've probably already charged around 700kWh on DCFC stations since I got mine. It's certainly a phenomenon in Teslas despite their thermal management, since they can limit your supercharger max rate, apparently, if you DCFC enough to result in battery degradation. That said, the one source I saw describing this said it happened to someone who'd put on thousands, if not TENS of thousands of kWh through DC fast charging.
I get that there's probably no threshold, but is the general principle the same as Tesla and supercharging? Or is the MME battery chemistry/management sufficiently different that you shouldn't need to worry about it unless you DCFC daily, for example (or some other extreme scenario like that)?
