Fat Mach
Nor Cal
2013 GT350
PRO TIP: Make sure you can loosen the Fill Plug before you remove the Drain Plug. The last thing you want to do is drain oil you can't readily replace.
Yes, the code can be resisted ;)
It was only a matter of time....
I remember the simple days when we would add a resistor to the ICP sensor on the diesel trucks to fool the PCM into commanding more Injector Pulse Width. Those were the good ole days.....:)
GoGoGadgetMachE
I just tried to click on your impact link, but it didn’t take me anywhere. I think the Internet might be broken.
its been broken since the ARPANET days but that's a whole different topic of conversation
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
And once again, another of my threads gets referred to. At least I know I provide good fodder. ?
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
Nice thing is, changing the oil in the MME looks easier than doing annual fluid changes on my Polaris ATVs. Still, even if I go with ever 100K miles, I’ll probably let the shop do it. For something that infrequent, I can probably save up the cash by then.
