ajmartineau
- Jun 23, 2020
- Washington
- 2021 Mach-E
If your Mach-E came before you had your L2 charger (or a Nema 14-50) installed you can still charge at L2 speeds by using an adapter or switch or a DIY plug and two 120-volt outlets. If you've been on the forum for a while, you've seen me post about this before but I haven't gone into any details because I'm not an electrician.
If you Google/YouTube search for a DYI welding plug or make a welding outlet hack, etc. many similar things will come up.
A Bolt owner Eric made this video. The adapters in his video could be used in other ways.
You can also buy an electronic adapter like this sold-out one.
I made my own adapter.
Here are examples of charging times for my Bolt to charge about 25kWhs starting on Thursday at 6:15 pm.
L1 granny charger: 12amp at 120 volts..... 20 hours!
DIY L2 adapter: 12amps at 240 volts ....9 hours 45 minutes
L2 Blink home charger: 32amps at 240 volts.... 4 hours!
The adapter works off two different 120-volt outlets (from different phases) because the power coming into your house is 240 volts but your breaker box splits it so most of your house runs off 120.
