JM22681
Jeff
MA
2023.5 Mustang Mach-E GT
there is no after-market beauty cover with 3 access holes that I am aware of. I don't know about the '24 design.
takes 10 minutes with a 1-7/8" hole saw.
get 3x 2" 'plugs' (50mm) from the hardware store, and you are done...
Yep, Amazon is out of the 2" so I got the 2.5". Does same logic apply where the hole should be 1/8" smaller?
santa fe,nm
www.envirokarma.org
Solar Sales/install
you can probably find 2" at your local hardware store. Or PM me with your address and $5 for postage, I have a bag of them.
alangant
Alan
Plano, TX
MME GTPE Rapid Red (ordered 10/22/21)
The 2.5" holes work great. There is a template for them in another thread.
JM22681
Jeff
MA
Yep, using it later today. Can you confirm 2 3/8 hole saw bit?
alangant
Alan
Plano, TX
I cut 2.5" holes for my 2.5" plugs. And I had to bend the retention pieces in a bit with plyers to be able to remove them!
Old_Norm
Columbus Ohio
These are extra battery access covers I 3D printed. The hole size would be 2.5 inches. If anyone wants them message me. Just pay postage from Columbus, OH.
Ford Mustang Mach-E How to DIY - add access holes for LVB 12v battery connection points & HV Disconnect Relay for Safety Mach E battery plugs
JM22681
Jeff
MA
Followed this procedure today using the 2.5" template. Awesome guide and thanks for quick responses.
@Old_Norm I will gladly send you a few bucks for those!
santa fe,nm
www.envirokarma.org
Solar Sales/install
AHoss75
Adam
Pennsylvania, USA
2023 MME premium AWD ER
worachj
Eagan, Mn USA
2023 MME Select AWD Rapid Red Metallic (03/10/23)
Hi, where can I find this template?
Did you use the 2.5" template? if so, I'm assuming you had to make these larger to fit (these say they are 50mm which equals just about 2"). What size did you end up setting them to?
I printed the 50mm size. Don't know where to find the 2.5 inch files.
I haven't drilled any holes as of yet. Still deciding if I want to spend the money to do FDRS updates.
santa fe,nm
www.envirokarma.org
Solar Sales/install
I don't use access points for FDRS.... I use the 12v for export to run little inverters, but have switched to using heavier cables for better connection anyway. I think some (easy) access to 12v is important to give/get a jump and or making it easy on the Dealership if and when they do a manual software update for you.
The THIRD hole, over the HV disconnect relay is probably more important, but less likely to ever be used. The location and access to this disconnect *should* be made obvious to first responders & tow truck drivers who most likely are untrained in where the 'cable cut point' is on the MME in case of accident where battery damage is suspected and they want to minimize chances of shorts/fires.
