connoisseurr
- Connor
- Sep 29, 2021
- Northern VA
- 22 Rivian R1T, 23 Tesla MYP
- IT Engineering
INTRODUCTION: The Mach-E, among other Ford vehicles, is capable of enabling the sideview mirror tilt when entering in reverse using FORScan software. Credit goes to @21st Century Pony for getting this modification pulled together. I'll admit stupidity that I attempted this modification on my 2021 Mach-E but didn't perform the Sync setting enablement, and proceeded to revert the FORScan changes. If you have a 2021, try this mod and let us know if you were successful.
PREREQUISITES: You will need the items below to perform this modification.
DISCLAIMER: Perform this modification at your own risk. FORScan, used incorrectly, may cause irreversible damage to hardware which may require a dealership visit, most definitely not covered by warranty. You accept all risk performing this modification, among any other modification using FORScan software.
INSTRUCTIONS:
USING THE MIRROR TILT FUNCTION:
Tilting of the side view mirrors will NOT work automatically. Tilting will only occur when either the left or right mirror button is selected (confirm with LED illumination). This is a Ford limitation, not a modification limitation. Also, both mirrors cannot auto-tilt down at the same time, unless you perform a manual adjustment.
So, when you are in reverse, or about to shift into reverse (doesn't matter which), select the side mirror you wish to tilt and the action will happen once in reverse. Once you shift to Park or Drive, the mirror will return to the normal position when driving forward or parked.
DIY RESOURCES:
Part C - Programming Walkthrough
- Latest version of FORScan (2.3.51 as of 01/25/2023)
- FORScan-compatible OBD2 dongle (OBDLink, Mongoose, Veepeak, etc.)
INSTRUCTIONS:
Part A - FORScan
- Open FORScan and connect to your Mach-E.
- As a recommendation, save a copy of your APIM data before proceeding (you should get in the habit of backing up any module you modify)
- Access the Configuration and Programming tab within FORScan.
- Locate the APIM Module configuration, making sure you select the module that DOES NOT have "AS BUILT format" in the name, and then click the Play button at the bottom of the window to run the service procedure. This configuration module allows the user to run scripts to complete various actions, rather than changing particular letters and digits within as-built code.
- You may get a pop-up alerting "Checking vehicle configuration". Review and click Ok to proceed.
- Locate Mirrors tilt in reverse. Double click, and then choose 1 - Enabled. Then, click the blue check box to proceed.
- At the bottom of the window, click Write to commit the changes. FORScan will ask you to power cycle the vehicle. Perform as requested.
- Exit the APIM configuration by clicking the blue stop button at the bottom of the window, disconnect your Mach-E from FORScan, and close the application.
Part B - Sync Settings Menu
- Turn on your Mach-E; accessory or full power.
- Access your Mach-E Control Panel (click the car icon; top left of the display).
- Select Settings, then Vehicle.
- Scroll down to find Mirrors, expand the menu item, and enable Reverse Tilt.
- Close the Mach-E Control Panel.
Part C - Programming Reverse Tilt
NOTE: Before proceeding, this modification requires you to have desired seat and side mirror settings mapped to the memory seat button assigned to your user profile. Please identify your memory seat button for the steps below.
- Turn on your Mach-E to full power. You will need to switch between Park and Reverse.
- Press and hold your user profile's memory seat button until you hear a beep. This will start the programming sequence.
- Select either the driver OR passenger side mirror and ensure the orange LED is illuminated.
- Shift the Mach-E to Reverse. Whichever mirror you selected in step 3, will now tilt to a default setting that you will change.
- Use the side mirror adjustment toggle to set your desired reverse tilt location.
- Press and hold your user profile's memory seat button for 5 seconds. You will hear a beep when you release the button.
- Shift the Mach-E to Park. The mirror will revert to your default position in about 5-10 seconds.
- As soon as the selected mirror returns to the standard driving position, press and hold your user profile's memory seat button until you hear a beep.
DIY RESOURCES:
