lweisenthal
- Larry
- Feb 8, 2021
- Huntington Beach CA
- Website
- weisenthalcancer.com
- MME Premium; RWD; std range; Chevy Volt 2.0
- Physician
O.K. I'll make this short.
Most Mach E reviews have to do with stuff like range, 0 - 60, general Mustang-nish, open road, mountains, winter weather, etc etc etc.
This is about taking your kids to soccer practice. Or just driving into work.
Here's the Executive Summary:
You want the drive mode to be "Low." One pedal is a gimmick. Kind of novel. Perhaps useful for some people with a personal issue. But otherwise, just messes with real driving, especially integrating Co-Pilot 360 features with the real world of American suburbia. "Low" is the perfect compromise between freestyle and dominatrix - regenerative braking wise. Your friction brake pads get 90% of the benefit, while you maintain ultimate control. Trust me on this, if you are new to this. Start out with driving in "Low" mode. After awhile, experiment with one pedal, if you are curious, or if you just were born to be a one pedal driver.
Set your adaptive cruise control to "Intelligent" mode. Thereafter, for most driving situations (exceptions would be late for work or going to the Emergency Room), turn on adaptive cruise control and lane centering. What you want to achieve is a state in which you and your Mach-E do a Vulcan mind meld. You don't drive the car. Spock (the MME) doesn't drive itself. It's more like Spock is a 3rd year resident in surgery. She does most of the operation, but you watch her like the proverbial hawk. The two of you make a great team.
What Spock does is most of the actual work. She keeps you in your lane. Adjusts your speed. Maintains proper distance (I suggest going with the "4 Avatar" car distance to begin -- the maximum separation between you and any leading (or cutting into your lane) car. I also suggest just setting the "Intelligent" cruise speed to the exact speed limit of the street on which you are traveling. Later on, if you want to dial it up to speed limit plus 7 or whatever, you can do it. But I advise against it. If you aren't late for work, just chill and listen to some good music or an interesting podcast. You'll arrive at your destination much more relaxed (and with less body odor).
Spock's job will be to keep you centered in your lane and adjust your speed and separation between the vehicle in front of you. Your job is to make sure that Spock doesn't accidentally sever the aorta. Plus you have to do the braking when you approach red lights or stop signs. Then, after you've stopped, you'll usually have to press on the accelerator to give Spock a little wake up call, as well as pressing the "resume" button in the center of your cruise control cluster on the left side of your steering wheel.
I've owned this car now a bit more than a day. Yesterday, I did a 130 mile drive on SoCal freeways. Today, a bunch of suburban driving in a wide variety of typical traffic conditions. Car has, to date, totally blown me away. As I wrote elsewhere, my expectations were sky high, and Spock (Premium trim, RWD, standard battery) has just melted (and melded) my mind. Awesome car. Just awesome.
Pro tip on lane centering: It won't work unless you have adaptive cruise control engaged. Also, when you change lanes, you have to turn your turn signal on in the direction of the lane change. The instant you do that, you control the direction of driving, not Spock. And until you turn the turn signal off, you are 100% in charge, not Spock. So be sure to turn the darn blinker off, once you are in the new lane of travel.
More, I'm sure, as time passes.
- Larry Weisenthal/Huntington Beach
