breeves002
- Sam
- Feb 21, 2021
- St. Louis, MO
- 2021 Mach-E GT PE
DISCLAIMER: DO THIS AT YOUR OWN RISK! While this shouldn't void any warranties or cause any issues it is considered modifying your vehicle in an unsupported way. I am not responsible for any damage you do to your vehicle. OTA updates could revert this change.
@Mach-Lee made me aware that non GTs didn't have the power meter. I decided to quickly do some digging and figure out if I could enable it on non-GTs. After about 5-10 minutes I had it figured out. We got it enabled on his Premium no problem!
NOTE: This WILL NOT WORK ON ALL VEHICLES! If your IPC software is too old, the power meter won't work. This is confirmed working on 2022 vehicles.
In theory, this should work on all Job 2 2021 vehicles and later. Older vehicles built before Sept 30 2021 should have had the IPC updated with FDRS to a new enough version for this to be enabled. BlueCruise OTAs may not provide a recent enough software version.
READ: FORScan guide: http://www.2gfusions.net/showthread.php?tid=4573
Recommended OBD adapter is the OBDLink EX or MX+. Windows laptop is required.
One change in the IPC is required. I recommend unplugging the vehicle from the charger before doing this though it isn't 100% necessary.
Change IPC Value:
720-11-02 x2xx xxxx
Do not change any X's (all but last 2 values should be 0). Once the value is changed hit "write" to the right of it. Hit yes to any checksum error. Restart the car and done! Note if the car is plugged in you will not see the power meter.
Power limiting grey bars: UPDATE: Limit bars do not work with this mod. These show the maximum power available on GT's. Max power can be reduced for a myriad of reasons including but not limited to the following:
-Battery too hot/cold
-Motors too hot/cold
-Low state of charge
-Speed of vehicle
Video showing power meter enabled on 2022 premium:
Change IPC Value:
720-11-02 x2xx xxxx
-Speed of vehicle
