- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
It is possible to use the 12v battery 'connection points' to EXPORT power... either to 'give a jump' to another vehicle, or run a (small-ish) pure-sine inverter that can be had for $300 or so to run a few AC loads, up to about 2000watts while camping, charging cordless tools at a job site, or even emergency power for your home if and when the grid goes down to run your 'critical loads' for as long as your HV battery holds out above 20% state-of-charge (SOC).
I've tested at least the simplest configuration, and it seems to work fine... as long as you understand the limitations of our MME and the systems that keep the 12v battery charged up from the big high voltage (HV) battery. The MME has plenty of Energy on board, but is a little limited in how much power can be exported via the 12v connection points.... and there are some 'tricks' to get things running and keep things running.
Here are the major considerations I know about so far (updated 2/18/23):
1. Access to the LVB connection points is a real PIA unless you cut an access hatch, or remove the driver's side frunk 'beauty cover'. at a minimum, you can cut (2x) 1-7/8" holes, and use jumper cables. Holes can be cut, and plugged when not in use per the DIY thread I wrote up a while back; https://www.macheforum.com/site/threads/how-to-add-access-ports-for-lvb-connection-points.4107/ I would suggest a third hole over the HV disconnect relay as well since that *should* be easier to access.
2. Power export limit - 1500 to 2000watts MAX - As far as I have found, the on board dc-dc that pulls energy from the HV battery to keep the LV battery charged is limited to a TOTAL of 160amps for most trim levels to all 12v loads including LVB 'charging/connection points' . If the MME is 'sleeping' and the LVB is depleted and voltage drops below 11.9, it should signal the dcdc to 'wake up' and recharge it. The dc-dc will then send energy from HV to run loads and recharge LVB back to 'full'..... UNLESS/UNTIL remaining charge on the HVB is less than 15%; at which point the HVB stops trying to maintain the LVB.
3. Because the LVB is so small; it is best to plan on turning the MME 'on' and disabling the 'auto-off timer' setting so the connection point voltage is maintained at 14.4 by the dc-dc rather than pulling Energy out of the LVB and forcing it to ask for support when it gets low.
4. Interestingly, you also need to close all the doors to enable the DC-DC to energize the 12v connection points. If doors are open, Energy is extracted directly from the LVB rather than from the HV battery. Note that if you are Exporting 1500watts of Power, the cables connected to the 12v connection points need to be big enough to carry 120amps of current or so.... I'd suggest 2AWG at a minimum. Regular jumper cables will work, but they will heat up significantly if you draw heavy load for very long.
5. minimum equipment needed
- 12vDC to 120vAC inverter - I'd suggest a 'pure sine wave' type which generates smoother power which is easier on your AC loads. Available for under $300.
- jumper cables for light loads... or more 'semi-permanent' heavy gauge (2 awg) cables with insulated connectors such as an 'Anderson connector' for better/safer connections
6. Tips
- When MME is 'on' you have the best chance of the dcdc system maintaining the connection point voltage at 14+v. If the voltage sags too much under heavy load, your inverter will turn itself off, or beep, or do some other type of alarm.
- if the MME is 'off', or sleeping, I don't know how long it takes for the dcdc to wake up to support heavy loads that pull the resting voltage down from 12.4. It looks like if the LVB sags down to 11.9-12.1 it will wake a 'sleeping' MME, but response from the dc-dc will be better if you leave it 'on' for full power to accessories.
- non-GT trims have a dc-dc converter that specs support for 160a. GT documentation shows a different part number for the dc-dc supporting up to 220a.... But I haven't verified the max or the expected duty cycle.
6. Tips
