bshaw
- May 18, 2020
- Boston, MA
- 2021 Mustang Mach E 4X (Job 1)
Good call, I like this idea. I just noticed that the 30A/120V cord I purchased to make this connection shipped with a plastic protector on the male end. I will keep this piece and store it with my modified cable.You could get a spare female plug end, and not add any wiring, to use it as a 'prong cover' when you are not backfeeding.
Yes, I was planning to wire up to the terminal connection for 30A.The 'terminal' output on these inverters is rated for 30a, the outlets are 15a.... so for backfeeding the house you should use the terminal connection from the Inverter for backfeed to house.
I have a 240 plug that I will jump across the two hots when modifying the cable. Since my cable is 120V, it only has hot/neutral/ground, so combining on the terminal is not an option.You COULD get an oven or dryer 240v 'pigtail' and hard wire it.... and avoid the work of taking apart the 240v male if you combine the L1 L2 at the terminal end. You will not be able to run any 240 loads, because the L1/L2 will be in-phase.... but it would energize both legs for 120 loads and you wouldn't have to take apart the 240v M plug end to add a jumper.
