- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
so, you had the car 'on' with timeout 'off', right ? did you turn off headlights too?I agree with Lee - if your modules have not been updated, that should be top priority. I did a test last year and my car was NOT maintaining my LVB when the EVSE was not connected. In February I had the dealer do all the updates and then tested again. I was able to confirm that the car maintained the LVB when not plugged in and off.
Before software updates:
After software updates:
The HVB charging finished at the 1:00 mark. At around the 8:00 mark, I disconnected the charger. You can't really tell when I disconnected the charger because now the car is maintaining the LVB just like it was when connected to the EVSE.
BTW - the LVB was draining so fast because I was monitoring the car with a OBDII scanner and CarScanner. Normally the LVB should never discharge that quickly, unless there is something else draining it.
This would mimic LVB maintenance while under normal 'on' background load which is around 200 watts. The ODB reader itself is a tiny load, but the background accessory loads for all the computers, modules, center screen, etc is pretty high.
The trickier maintenance mode for the LVB is when MME is 'sleeping'. background loads *should* be tiny, which means that 'periodic' wakeup checks *should* catch it before it goes too low to wake up. This measurement is hard to catch unless you have an external data logger or leave the hood up and check manually without waking up the MME
...if everything is working properly, it works great.
...if HVBJB is damaged, or modules are stuck way back with bad parameters, maybe not
I had CSP 21p22 updates done while they did my windshield recall, and never had a problem w LVB.
