How to start Mach-e without FOB or PAAK?
Motomax
Max
VW GLI, 4Runner
Slide into the seat to see no key detected. Spend a couple minutes hoping the prompt shows up on the screen.
I would not recommend “waiting and hoping” as good troubleshooting steps.
:p
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
:p
You are correct. It’s too cold for waiting and hoping. I’d be doing the get in, get out, push start button, hold brake. Push start again. Open door. Hokey pokey routine trying to get the prompt to show up. If nothing else the mild calisthenics would generate some heat.
Ford made a video that shows the difficulties some may realize:
Ken Josing
Ken Josing
Ken
Moorpark, CA
2021 Ford Mustang Mach-E
Has anyone actually got the Mach-E moving without the FOB or PaaK using codes ??????????
Yes. Quite a few people have used the passcode. For others, it's problematic to get to the prompt for it. With this vehicle, there are so many variables (OTA update versions, dealer module updates, phone model and OS, etc.) that it makes the technology iffy at times for many. If I was going to rely on the passcode, or PaaK, I would carry my fob in a farady bag or similar for a long period and ensure I had no issues. Given the alternative is simply carrying the fob and having no issues, ...
Yes. I do it all the time. Normally on weekends when I need to move the car so I can get another one out of the garage. (My MME parks outside in the driveway...)
My fob is inside the house and of course PaaK doesn't work so I use the door pillar code to enter the car and then the backup start code to drive the car whenever.
Your car isn't bringing up the backup start code. Not sure what the fix is. Might need some modules recalibrated. Your dealer should be able to do that for you under warranty.
FordMachEGo
SoCal
2021 Premium AWDx April 2021 build.
I assume it's possible. First I entered the 5 digit factory given number into the door. Once in I got the screen active, but I was unable to put the 8 digit password in. Tried and tried with no success. I read the help in the owner's manual nothing. It made some reference to a 10 digit code, no idea what that's about and again where to put it if I had it.
Did you try hitting the start button with your foot on the brake multiple times? Sometimes it takes 3-5 tries (pausing between tries), before the car displays the password prompt. I’ve done this many times and it always works. Make sure your PAAK shows it’s still set up in Fordpass. If it is you will see a second set of buttons under the Start button. If it’s not, you will see a message and button labeled “Set Up Phone As A Key”
alexgorod
Alex
DBA
It works much better without the foot on the brake, in my few tests it worked every time.
Now that's interesting, since the foot off the brake should just turn on Accessory mode... ?
alexgorod
Alex
DBA
It did, and prompted that key was not found. I waited for the screen to boot up, pressed the button again to turn it off, and on next press it prompted about the key again, I pressed OK on the wheel, and password dialog appeared on the screen.
Maybe if I pressed OK on the first prompt it would be enough, I'll go and try again :)
AzCoronaDog
Scottsdale, AZ
'12 Porsche 911 Cabriolet, '21 MME, '17 Yukon XL
Yes, I have on a couple of occasions.
The first time was right after I did the backup code setup, to test that it really worked. (did not have my phone or fob anywhere near the car.) The door code and the start code worked as advertised.
The next couple of times was when I needed to move the car out of the garage and did not have my phone on me (the wife keeps the fob). It was not locked, but the start code thing came up as expected and it worked. I may have had to try the start button more than once, I don't remember. But once the prompt came up it took my password just fine.
I do have issues with the car seeing my phone though. I have found that if I open the app and use the unlock button, it will recognize my phone after that.
alexgorod
Alex
DBA
Confirmed - without the key and the phone, pressing the "Start" button without the brake pedal and then OK on the steering wheel opens the password dialog (after an attempt to connect to Android Auto, maybe about 10 sec. )
bruceski88
Bruce
CA
Mach e
Yes I’ve used it but I’ve noticed that once apple CarPlay connects the prompt goes away.
It’s funny how CarPlay will connect, but the MME won’t recognize PAAK
Motomax
Max
VW GLI, 4Runner
There’s a couple factors at play. Paak tried to measure the distance of your device using the Bluetooth connection (which is not accurate), if it thinks it’s too far it won’t activate. This is why people say to place the phone bellow the screen, personally holding it in my hand while pushing the button works great.
Paak is also authenticated by the fordpass app. Sometimes you might need to force quit the app and reload it.
