How to tuck cable behind screen?
GoIrish
Los Altos, CA
Mustang Mach E Premium AWD Ext Range
See attached pic. Does anyone know how I can tuck this cable behind the screen?
Kabish
2021 Mach-E Mustang
They sell zip ties that have adhesive backings to them. You could stick one or two to the back and then zip tie the cord. Just keep in mind, anything you stick to the back has the potential of causing damage when/if you try to take it off.
A positive thing with this though is that you can just cut the zip tie and leave the base. So you could easily replace the holder if you wanted too.
Ford Mustang Mach-E How to tuck cable behind screen? 1637385406071
GoIrish
Los Altos, CA
Great idea! I was going to try to take the screen down, etc. this might be easier lol
GoIrish
Los Altos, CA
So the wire will still be visible...does anyone have instructions on how the panel below the screen can be removed?
GoIrish
Los Altos, CA
I can't help with your cable, but you use the heated seat and steering wheel when the temp outside is 61F? That's shorts weather around here with the windows open.
V nice attention to detail...guilty!
Polar
SBJ
PNW
2021 Select RWD SR
Buy a longer cable and run it around the long path along the top edge of windshield, down the A pillar, and under the dash.
Hard as hell to see in the crappy pic but how is the mount mounted? To the glass or the top of the screen?
GoIrish
Los Altos, CA
Mount is mounted on dashboard, I'll post a less crappy pic soon. Long cable is not an option, would be even more prominent...
