- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- MME (delivered 2/26/21), DIY eMiata BEV
- Solar Sales/install
Until Ford add's some kind of way for us to view things such as charging rate, power consumed, and power regen, FORScan is our only solution.
Unfortunately as of today the current test build does not show battery current. It will show charger current so you can see that info as well as battery voltage - but you can't see how much power is coming in or out of the battery while driving yet. FORScan lite (phone app) isn't updated to work with Mach-E yet. That is also coming.
Test build download here. It works properly, just does not have all PIDs yet.
SO COOL!
I'm very excited about this. I don't want to change any programming of anything, I just want to display data-stream for actual traction pack voltage, and current output/regen.... and even better if I could display Volts/amps and calculate kW
so.... I will definately watch for news of the appropriate PIDs being available !
