- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
Just wanted to post a couple pix of my 'mid-size' Portable power unit... 2kWhr of Lithium battery, 3000watt pure sine inverter, and a custom cord are all you need to keep it charged from your MME by accessing the 12v connection points for 'extended use' or re-charging when you need to, and then roll the unit away from the vehicle to wherever you need power.
This 'larger' unit can handle peak loads over 3000 watts, but really intended for average loads for a couple hundred watts.... which is enough to run all the basics in a house, including the refrigerator, in a pinch. Backed up by a MME, it could run for DAYS if the Grid is down. Or, you can use separate solar panels to recharge and treat it as a nano-grid to energize a home, campsite, or job site.
I have done a couple of the smaller units (1kWhrbattery and 1500watt inverter) that fit in a carry on which drops neatly into the Frunk, and is a lot easier to lift and transport....
The 'charge' cable from MME 12v doesn't need to be very big as current is naturally limited by the relatively small voltage difference between auto at 14.4v and (loaded/depleted) portable batteries than might sag down to 12.0.
I mostly just wanted to share the idea with MME Owners so you are aware you have the perfect 'emergency backup' energy stored up in your MME!
