I can't believe the repair costs. Watch weight in the rear.
Chuck518
Chuck
Ray Brook, NY 12977
Ford Mustang Mach-e
Electric Vehicle Supply Equipment. Most people call it a charger even though that's not technically correct since the charger is built into the car.
Would this be supplemental to the built in charger? Why would somebody want one?
It's the only way to connect the internal charger to the AC electrical grid. It's the cord that plugs into the car.
RMoore
Why would anyone want the upper position?
There are several reasons, some of which have been mentioned in subsequent posts. I actually moved mine to the lower position since I was aware of the weight issue from this thread, but I often put a few things in the trunk and it would be nice to be able to drag these over the lip rather than lift them the way I now have to (tennis bags with racquets etc). So I'm tempted to move it back to the higher position for ease of use. I wish there was some weight limit listed though I suspect our tennis bags would be OK. I would think Ford would be required to repair these under warranty given the lack of clarity on the use of the upper level and any warning about weight limits.
sotek2345
Tom
Upstate NY
Engineering Manager
What does EVSE mean?
EVSE = electric vehicle servicing equipment.
Others also call it the mobile charger, but it isn't really a charger - the charger is in the vehicle.
Or you can use a sealed box designed JL sub as I do which is smaller than the ported box and keep the floor in the lower position. I have an 85 lb. lab who jumps in and out of the cargo area all the time and also goes on long road trips with me (up to 4 hours). I'm certain those plastic floor supports would have broken by now if I had the floor in the upper position.
Lab tested. ;)
ZuleMME
Zule
Denver, CO
21' Job1 P4X MME, 22' MYP
Implementation Engineer
servicing = supply
dbsb3233
TimCO
Colorado, USA
I gave up on the privacy cover within a week. On occasions when I have to leave something in the car that I don't want others to see, it goes to the frunk.
Two words: zip ties!
I threw a dozen small zip ties (and a nail clipper) in the car and zip one on each spindle to keep them from popping out anytime that delicate cover touches anything. That works great. When the hanging edge of the cover hits a suitcase now, it's just slides over the top like it should.
The rare time I need to take it off, I just clip the ties. They're cheap.
jhalkias
Benefit Fund Administrator
I haven't trusted those since the day I saw them and immediately lowered my load floor. Besides that, with the rear mat, the mat fits much better with the floor lowered.
Sorry this happened to you.
MachE70
Utah
2021 Kia Telluride SX, 2022 Mustang Mach-e GT
I "fixed" the obvious cargo floor design flaw in my $71,000 GT using two of my wife's yoga blocks, an extra shelf from my basement kitchenette, and an AAA emergency kit. The cargo floor now has several more areas of support in the upper position. Now, we can just continue to play HVBJB roulette as the wife and I drive the car on a daily basis while we wait for that "fix". Nice work, Ford.
ricksta6
Rick
Chicago, IL
2021 Mach-E Select Rapid Red
I had the same thing happen to me. Never even knew that there were two positions for the trunk before it happened. Thankfully, Ford agreed to warranty the damage.
This just happened to me. May I ask how you got them to agree to warranty the damage? I have a feeling it'll be a painful fight.
MoonRiver
Tampa Bay, FL
02 Camry, 07 Infiniti G35
So, I was bringing some flooring home from Home Depot. Loaded it the back. The little thing that holds the rear deck in place pulled out.
Parts cost alone is $650.. Full inner panel must be replaced! What a crap design!. I'll make my own support and attache it in an intelligent way. Anyway, watch what you load in the back. And if it weighs anything at all, watch for bumps.
Sorry to read op's story. It could easily happen to me too. Mine arrived with the tray on the top. I better lower it to the bottom. Thank you for warning us. As soon as I get back home I will think about supporting it better from underneath. It's indeed a faulty design. If they didn't want to make it stronger they at least could have stuck a weight limit sticker there.
MoonRiver
Tampa Bay, FL
Is it only happens on the 21 model? I hope they changed on the 22 model. Mine is 22.
