TheStig
- Rob
- Jan 22, 2021
- Michigan
- 2021 GB Mach-E FE, 2023 Porsche GT4
I had an order in for an Infinite Blue Premium, but was mad I missed the chance to get Grabber Blue. Well, I got lucky and was able to just get one off a dealer lot. Even got to use A/Z plan.
I’ve only taken pictures in my garage because it is like 10 degrees outside.
My impressions of it are mostly positive after messing with some settings. It is bigger than I thought it was going to be. I thought it wouldn’t be much larger (longer and wider) than our Prius, but it is. I wish it had a way to make the mirror retract when the car turns off instead of when you lock or walk away from it. If that setting exists, I can’t find it.
I had a lot of trouble getting the FordPass to connect. I had to delete the car and activate it a second time for it to work. I also can’t figure out how to push my settings from the phone app to the car. The instructions say that there should be a “send to vehicle” button somewhere, but there isn’t. So I am just stuck with the profile picture from the profile I made in the vehicle. I was able to connect my profile with my PaaK from the app, I just can’t change the profile picture or send trips or anything because of the lack of a “send to vehicle” button. I’ll probably get in contact with ford at some point.
One thing I do want to complain about is build quality. I haven’t owned an American car in a while and I thought it had improved more than it has. It’s not Tesla bad, but it is no Porsche or BMW. Put this next to a Macan and touch all the surfaces and tap and push on panels, and it is obvious which one is made better.
I’ll post some better picture and give a better review when I get more time with it.
