silverelan
- Nov 25, 2019
- Seattle
- 2021 Mustang Mach-E GT
See this other post: https://www.macheforum.com/site/threads/revised-charging-curve-video-and-data.17121/Is there a Mach-E's graph of the charge for comparison? For someone like me that isn't familiar, I can't figure out what part of it we should wish for?
The shapes of the curves aren't exactly the same. However, for practical purposes, I feel like the shape difference doesn't matter that much. What's definitely different is that Mach E appears like roughly 2/3 of Lightning throughout the curve.I wish MME had F-150’s charge curve
I think it probably has more to do with the battery size.I wonder if the extra chiller in the tow package would have any affect on this.
KW is really the wrong measure of charging speed for batteries of vastly different sizes. Apples to apples the comparison I think would be % of battery Kwh capacity as the vertical axis, time as the horizontal axis. MME caps out at 1.5C The Lightning appears to do the same. In that sense the Ford batteries charge rather similarly.For a truck, the F-150 is not charging very fast. Hummer and Silverado will go at 350kw at the lower end of SOC. And the Hummer stays above 200kw out to at least 60%.
the SR and ER packs are 3 minutes apart on 10-80% times, 38 and 41 mins, respectively.See this other post: https://www.macheforum.com/site/threads/revised-charging-curve-video-and-data.17121/
This isn't all that surprising considering that ER Mach E has 91 kWh usable, compared to ER Lightning's 131 kWh usable. That's roughly 2/3. This is consistent with the two vehicles having roughly the same 10-80% charging time.
My MME will add 6 mile/min, which is about what the F-150 will do. When I get my Hummer it will be 9 mile/min. That is what countsKW is really the wrong measure of charging speed for batteries of vastly different sizes. Apples to apples the comparison I think would be % of battery Kwh capacity as the vertical axis, time as the horizontal axis. MME caps out at 1.5C The Lightning appears to do the same. In that sense the Ford batteries charge rather similarly.
Consider that the hummer burns ~ more than twice as much energy to move a given distance as my MME... it better charge faster because drains the batteries so fast.
Hummer 47 MPGE
Lightning 68 MPGE
MME 100 MPGE (SR RWD)
Naturally it will charge faster due to its 30+% larger battery, but that’s not the whole story. For practical purposes the shape is what matters specifically the area under the curve, and the Lightning’s flat curve is definitely better than the MMEs. Not sure if it’s cooling, battery design, or software limited.See this other post: https://www.macheforum.com/site/threads/revised-charging-curve-video-and-data.17121/
