Murse-In-Airy
- Rod
- Mar 5, 2021
- Chaumont, NY
- Mach-E ER AWD
- Nurse
Ok. Iāll look into this and see what I can find. Though with my work schedule and my sonās 16th Birthday, it might be a bit before I get a chance. Iāll keep you posted. Thanks again.That area is on the drivers side not passenger side. There is one like it on the passenger side that you saw but it comes into an area you cannot get to easily without taking half the dash apart. The one on the drivers side comes through just above the steering column and is easy to get to. You then would have to run the wire across to the passenger area under the glove box.
I checked the wiring diagram of all the fuses in the frunk area and none of them will work for what you are looking to do.
Right now you have your emblem coming on only when the head lamps are on. There are three other ways I see you can wire up your emblem.
1. You can have it illuminate anytime the car is in the ON position. However it will not illuminate when the head lamps are on (unless the car is on) or with the welcome lighting. This can be done by tapping into a fuse under the glove box.
2. The pony can illuminate with the welcome lighting and anytime the head lamps are on but NOT while the car is on (unless the headlamps are on). For this you need to tap into either the Green/Orange or Brown/Yellow wire coming off of the center Black connector of the BCM.
3. Your pony can illuminate anytime the daytime running lights are on which is pretty much anytime the car is on. It will also be on when just the headlights are on and with welcome lighting. For this you have to tap into the Gray/Blue or Violet White wires again coming off the center black connector of the BCM.
I have not actually tried any of this yet as I am still without my car but will do the first of next week when I get home. You may get to test these connections out before I do. Again, like I said before, if your LED lighting pulls more current than the system likes, It will start blinking and give you a head lamp system fault warning.
