RVAtom
- Adam
- Jul 21, 2020
- RVA
- Mustang Mach E
Power-Ups:
These updates should roll out to your vehicle automatically over the air (OTA). Not all vehicles are released to receive updates at the same time OTA, and depending on the update, some vehicles may have to wait a meaningful amount of time to get the download.
2.8.3 -
2.8.2 -
2.8.1 -
2.7.5 -
2.7.4 -
2.7.3 - Similar to Early Access 2.4.3 -
Several display updates to the small display (IPC)
2.7.2 - Similar to Early Access 2.4.2 -
Updated brake pedal feel
Updated charging curve above 80%
2.7.1 - Similar to Early access 2.4.1 -
Enhanced version of Horn and Lights in Fordpass
2.6.0 - Similar to Early Access 2.3.0 -
Ford assistant, Speed sign recognition and more. Enhanced version of previous update.
2.5.3 (Early Access Number)- 03/12/2022
"Minor adjustments to help you enjoy the journey ahead."
This update was targeted at the APIM (the big Sync display)
2.5.2 (Early Access Number)- 03/11/2022
"Small changes here and there..."
As of this update, drivers should be able to activate BlueCruise.
2.5.1 (Early Access Number) - 03/09/2022
"Ongoing updates like this help you enjoy the best possible version of your Mustang Mach-E™ vehicle. Enjoy."
There is some discussion about the size of this update. It seems to be one of the final Power-Ups needed to enable BlueCruise.
2.4.4 (Early Access Number)- 03/02/2022
A small adjustment to prepare for future updates
2.4.3 (Early Access Number)- 02/26/2022
"Minor updates here and there"
2.4.2 (Early Access Number)- 02/25/2022
Smoother braking. (First OTA to change powertrain function!)
2.4.1 (Early Access Number) - 02/09/2022
Horn and lights button in FordPass
Some confusion around this update, as most people already had that button. This update might have been more back end stuff getting ready for something in the future
2.3.0 - 01/07/2022
Sync Version # after update: 21281-???
Ford Assistant, Multi-Day Scheduling; more feature enhancements
2.1.0 - 12/13/2021
Sync Version # after update:21174-168
Minor updates here and there.
1.7.1 - Septemper 29, 2021
Sync Version # after update: 21174-168
Major OTA update
1.6.0 - July 14, 2021
Sync Version # after update: 21139-263
Minor fine tuning to keep everything running smoothly.
There was extra drama around 1.6.0 and 1.4.0 due to some cars receiving Power-Ups out of order (1.6.0 --> 1.4.0)
1.4.0 - June 28, 2021
Added SecuriAlert
TSBs:
Technical Service Bulletins (TSBs) are different from Power-Ups because any given vehicle may or may not receive these updates. Generally these are installed by the dealer after you have presented your vehicle with some issue present.
TSB 21-405
Illuminated Powertrain Malfunction (Wrench) Indicator - Various Diagnostic Trouble Codes (DTC) - Built On Or Before 09-Sep-2021
TSB 21-369
Glass Roof - Wind Noise From Upper Windshield Area Above 45 MPH (72 Km/H) - Built On Or Before 15-Feb-2021
TSB 21-2310
Various Sync4 Concerns
TSB 21-2307
Water Leak Into Liftgate - Built On Or Before 01-Jul-2021 21-2307
TSB 21-2288
Cooling Fan Noises During Level 2 Charging - Built On Or Before 11-Aug-2021
TSB 21-2278 (Rescinded by Ford)
Cooling Fan Noises during level 3 charging (public charging or wallbox)
TSB 21-2249
Various Driver Assistance Feature Concerns And/Or IPMA DTCs
TSB 21-2245
Loss Of Power, Stop Safely Now Message In The IPC, Illuminated MIL With DTC P1A10, U0293 And/Or U1011 - Built On Or Before 20-Mar-2021
TSB-21-2244
Illuminated MIL And DTC P061A, P1A1E, And/Or P2533 - Built On Or Before 7-July-2021
TSB-21-2206
Vibration/Pulsation From Brakes - Brake Pad Material Stuck To Rotor
TSB 21-2190
Illuminated Powertrain Malfunction (Wrench) Indicator With DTCs - HV Battery Not Charging At Level 3 DC Fast Charging Station/EVSE
TSB 21-2189
Front Luggage Compartment Hood Closing Effort
TSB 21-2171
Inoperative Level 2 Charger/Inoperative One Pedal Drive/Powertrain Malfunction (Wrench) Indicator/ABS Lamp On With DTCs - Built On Or Before 11-May-2021
TSB 21-2123
Level 2 Charger Inoperative - Built on or Before 14-April-2021 - Released April 22 2021
TSB 21-2091
12-Volt Battery Becomes Discharged While The Vehicle Is Plugged In During the High Voltage Charging Process
TSB 22-2117
Ford Power-Up Software Update Failure Message And/Or Unable To Update The APIM Or TCU With The FDRS And USB Drive - Module Recovery
TSB 22-2144
Parking brake fault service now message in cluster
Special thanks to @breeves002 for posting all of these TSBs and making this part easy!
Recalls:
21C36
Rear seat belt anchor repair
21S42
Panoramic roof glass reseal
21C22
Windshield glass reseal
21C36
Improperly attached rear seat belts on some vehicles produced from 10/6/21-11/20/21
SSMs:
CSPs:
Customer Satisfaction Program
CSP 21P22
Software Calibration Update
2.8.3 -
2.8.2 -
2.8.1 -
2.7.5 -
2.7.4 -
2.3.0 - 01/07/2022
2.1.0 - 12/13/2021
Major OTA update
- APIM Module Update Only
- Sync update
- Added non working frunk button
- Added notes drawing app
- Calm screen (press and hold on volume knob)
- Carplay on cluster display
Added SecuriAlert
TSBs:
TSB 21-405
TSB 21-369
TSB 21-2310
TSB 21-2307
TSB 21-2288
TSB 21-2249
TSB 21-2245
TSB-21-2244
TSB-21-2206
TSB 21-2190
TSB 21-2189
TSB 21-2171
TSB 21-2123
TSB 21-2091
TSB 22-2117
TSB 22-2144
Recalls:
21C36
- applies to vehicles built between 10/5/2021 and 11/18/2021
21S42
21C22
21C36
SSMs:
Published | ID | Supersedes | Superseded by | Title | Subject | Change (potential) |
1/18/2021 | SSM 49457 | Various SYNC 4 System Concerns -- SYNC4 System Reboot Procedure | how to reboot SYNC 4A | |||
1/29/2021 | SSM 49511 | High Voltage Battery Coolant Expansion Tank Above The Max Fill Line From The Factory | ignore max fill line, only min fill line is relevant | |||
2/6/2021 | SSM 49545 | Various Warning Messages With Diagnostic Trouble Code (DTC) C1B00:62 In Power Steering Control Module (PSCM) | various power steering (PSCM) related concerns | |||
2/22/2021 | SSM 49603 | TSB 21-2190 | Illuminated Powertrain Malfunction (Wrench) Indicator With DTCs - HV Battery Not Charging At Level 3 DC Fast Charging Station/EVSE | powertrain malfunction (wrench) indicated after L3 charging; ignore | OBCC | |
3/3/2021 | SSM 49643 | Android Auto Not Wirelessly Connecting And/Or Android Phones Rebooting When Connected To The Vehicle Via USB | Android Auto not connecting or crashing | Chrome browser | ||
3/12/2021 | SSM 49655 | Android Auto Not Wirelessly Connecting And/Or Android Phones Rebooting When Connected To The Vehicle Via USB | Android Auto not connecting or crashing | Android Auto | ||
3/15/2021 | SSM 49663 | Check Navigation System Operation Before Delivery to Customer - Built On Or Before 10-Dec-2020 | Map navigation not functional | navigation app | ||
3/17/2021 | SSM 49673 | Sirius Presets/Audio Settings Not Saving After A Key Cycle - Engineering Investigation | audio settings not persisting | |||
3/17/2021 | SSM 49672 | TSB 21-2189 | Front Luggage Compartment Closing Effort | closing force required to close front hood / frunk | ||
3/18/2021 | SSM 49676 | Alarm Activates When Unlocked Door Opened - Driver Door Does Not Unlock/Open - Door Activation Switch Not Lighting Up | driver door does not open, or alarm activates | BCM | ||
3/25/2021 | SSM 49691 | Missing Keyless Entry Secure Code Card | missing keyless entry secure code card | |||
3/25/2021 | SSM 49690 | Module Replacements When Using FDRS | module replacements when using FDRS | |||
4/9/2021 | SSM 49730 | Phone As A Key Concerns Of Bluetooth Disconnected, Unable To Start, Backup Code Needed And/Or Key Not Detected | PaaK reliability | RFA | ||
4/15/2021 | SSM 49737 | Audio Inoperative - No Sound From Audio Speakers - No Communication With ACM Or DSP - DTC U1084, U0237 And/Or U0238 | audio inoperative | DSP | ||
4/28/2021 | SSM 49756 | FDRS Not Showing A Module Listed That Requires Updating | software downgrade prevention | |||
4/29/2021 | SSM 49758 | P0AA6 In Battery Energy Control Module (BECM) | MIL P0AA6 in BECM | |||
5/6/2021 | SSM 49784 | Various Phone-As-A-Key Concerns | various PaaK concerns | |||
5/12/2021 | SSM 49795 | Unable To Perform Remote Commands Via The FordPass/LincolnWay App - Erroneous Deep Sleep Message | deep sleep, unable to perform remote commands (FordPass) | |||
5/21/2021 | SSM 49811 | A/C inoperative - Heater Inoperative - Ambient Temperature Reads -4 Degrees | AC inoperative, temp reads -4 degrees | |||
5/21/2021 | SSM 49810 | Buzz Noise From The Instrument Panel Cluster (IPC) | buzz noise from instrument cluster | |||
5/24/2021 | SSM 49820 | Missing Authorization, Command And Control Or Phone-As-A-Key Buttons In FordPass Or LincolnWay App | missing buttons in FordPass app | |||
5/28/2021 | SSM 49836 | Unable To Authorize The FordPass/LincolnWayApp - No DTCs Present | connected services activation failure | |||
6/5/2021 | SSM 49860 | High Voltage Battery No Charge Condition | HV battery no charge condition | |||
7/8/2021 | SSM 49944 | SYNC 4 - Various SYNC Concerns - Engineering Investigation | SYNC 4 various concerns | APIM | ||
7/15/2021 | SSM 49962 | Reverse Brake Assist Unavailable After Module Programming | reverse brake assist unavailable after programming | |||
7/21/2021 | SSM 49968 | Phone-As-A-Key Concerns - Various DTCs In The RFA module | PaaK concerns, DTCs in RFA module | RFA | ||
8/4/2021 | SSM 50004 | FordPass Master Vehicle Reset - Phone As A Key And Backup Start Passcode Revoked | FordPass vehicle reset, PaaK revoked | |||
8/8/2021 | SSM 50015 | Enhanced Windshield Anti Fogging Strategy (EWAFS) | Enhanced Windshield Anti Fogging Strategy | |||
8/16/2021 | SSM 50039 | 2016-2021 Various Ford And Lincoln Vehicles - SYNC 3 and SYNC 4 - Issues With Vehicle In Transport Mode | properly transition vehicle out of Transport mode | |||
8/17/2021 | SSM 50045 | 2018-2021 Various Ford and Lincoln Vehicles - Wireless Charging Pad Inoperative/ Slow Charging - iPhone 12 Users | Wireless charging pad is Qi compatible | wireless charge pad | ||
8/24/2021 | SSM 50064 | 2013-2021 Various Vehicles - Noise When Brakes Are Applied | noise when brakes are applied | brake pads, brake rotors | ||
9/1/2021 | SSM 50077 | 2020-2021 Corsair/Nautilus/Navigator/Aviator, 2021 Mustang Mach-E - Phone-As-A-Key Concerns - Various DTCs In The RFA module | various DTCs in RFA module impacting PaaK | RFA | ||
9/17/2021 | SSM 50140 | 2021 Mustang Mach-E/F-150/Edge - Gateway Module (GWM)/Telematic Control Unit (TCU) Programming Failure | Gateway Module or TCU programming failure | GWM, TCU | ||
9/24/2021 | SSM 50151 | No-Start With Stop Safely Now In The IPC | Low 12V with No-Start and Stop Safely Now messaging | 12V battery charge | ||
9/29/2021 | SSM 50162 | 360 Degree Camera System - Reverse Brake Assist Unavailable Message And DTC B1578:78 In The IPMA After An On-Demand Self Test | reverse brake assist unavailable after self-test | 360 degree camera view alignment | ||
10/6/2021 | SSM 50173 | Front Suspension Noise - Front Spring Spacers - Built On Or After 26-Jul-2021 | remove front spring shipping spacers | |||
10/7/2021 | SSM 50176 | 2021 Mustang Mach-E - Key Fobs | 2 key fobs starting with 07-Jul-2021 build dates | |||
10/20/2021 | SSM 50213 | FordPass App Frunk Button - Failure To Open Message | FordPass frunk button doesn't work | BCM, FordPass | ||
11/19/2021 | SSM 50300 | 2021 Mustang Mach-E - Unable To Achieve 100 Percent State Of Charge After HV Battery Module Replacement | unable to reach full charge after HV swap | BECM, HV battery |
CSPs:
CSP 21P22
