- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
I'm thrilled with results.... new wheels are an inch wider, 6.5# lighter, and the alloy nuts take off about 10oz more per wheel!
I finally got all the bits in house, and had a local tire shop slide the stock tires from my Select onto my new wheels. I figure I will run the OEM tires until worn out, and then go for nicer, wider, sticker summer tires. I'll put some nice Snow/Ice tires on the factory wheels for winter when it snows since I do hit the mountains for skiing, etc...
My goals in wheel selection were to stay at stock diameter, reduce weight as much as possible while sticking with a 700kg rated wheel, and hold the cost down as much as possible.... which means one-piece alloy, probably with pretty much straight 'spokes'. I found choices somewhat limited with correct bolt circle and offset; but decided on:
18x8.5 Enkei TS-V, part number 522-885-3140 - 19.5#, 5x108bc, 40mm inset, 72.6 bore
I got mine from pattersonperformanceparts.com
set of 4 delivered for $1000 even
note that OEM Select wheels are:
18x7.5 - 25.6#, 5x108bc, 63.4 bore
This means I also had to get
+ $14 for 72.6-63.4 centric rings :
.amazon.com/ZHTEAPR-Wheel-Centric-72-6mm-63-4mm/dp/B08L8VVDDW/ref=asc_df_B08L8VVDDW/?
+ $164 for valves+TPS+'activator' : .americanmuscle.com/search?keywords=389789
+ $55 for 14x1.5 lug nuts because factory nuts have a chrome cap that doesn't fit in Enkei holes : vmsracing.com . I got Alloy, which are almost 2 oz lighter than stock per nut! but.... you do have to be careful with them, use anti-seize, and hand-torque rather than impact wrench
