MyLittlePony2022
- William
- Jul 17, 2021
- SF Bay Area, California
- 2022 "Mach-E Auto" GTPE, Cyber Orange
There have been several threads with input on how to install new speakers, including a sub, and new amps. Most of the information is on the forum in pieces, but being a geek and wanting to know I plan to do it, I did the research. Apologies about the length of the post but I want to be precise.
I am working on picking my components and probably will start with the speakers first and then look at new amps further down the road. Thanks to everyone on the forum who has provided all the great information. Below is what I know and other can help enhance the knowledge. Hopefully, someone has replaced the amps themselves and can provide real-world data. Some of the members on the forum have had amps professionally installed but specific details are not known about the means and methods.
Links to some of the threads that have the information
Subwoofer replacement
Discussion on B*O System
Ford factory A²B® (Automotive Audio Bus) & SYNC3
Specifications on B&O system
- 560 watts (not sure if that is RMS or peak)
- 9 speakers and sub
- Front dash and rear door speakers: 25mm or 0.98 inch tweeters ( 1 pair per)
- Center dash speaker: 80 mm or 3.15 inch mid (One speaker)
- Front door and rear door speakers: 160mm or 6.3 inch mid (1 pair per)
- Rear woofer: 160mm by 236mm or 6.3 inches by 9.29 inches
The front dash tweeters and center speaker are fed from the head end unit (radio) directly into the wiring harness and to the speakers. By assumption, the amp is within the head end unit and the signal must be analog. I am waiting on Crutchfield to put my speakers on sale and then my amplifier. Not in a hurry so I will wait for a sale. Also, need to do some more research and investigation on speaker dept.
The head end unit sends a digital signal to the rear amp via the harness. The rear amp send signal to the front door mids and the rear door mids and tweeters.
The head end unit sends a signal to the subwoofer amp, in the rear, via the harness. The rear subwoofer amp send signal to the subwoofer. This is analog.
Replacement of the speakers should be fairly simply and most depths should work. I have not seen any post on the exact depths that will work. I will take measurements and pictures when I do my replacements and post.
Adding aftermarket amplifier(s) is a bit more complex.
Per JL Audio recommendation, I ran an 8 gauge for my subwoofer and it was fairly easily. I ran it on the drivers side. I could not cleanly run it under the door sill covers and had to do a small spot near the driver's seat between the frame and the carpet.
If you plan to run power for multiple amplifiers, don't forget to do the math to determine the correct power cable size and fuse size running into the your fuse block. The fuse block becomes the distribution to the amps but also add another fuse protection for the amp. See link for videos of determining wire size and fuse size. There are tables that also help to determine the wire size based on the length of the wire run.
Finally, if you are a geek like me, I am going to put sound deadening on the doors to help the acoustics. See the following: link 1, and link 2. If you like to research an determine the best way of doing an install, I would suggest looking on Car Audio Fabrications' website.
Hope this helps and please help add to the knowledge base.
- The OEM rear amp receives a digital signal. Amplifier integration interface is required to convert to an analog signal for the aftermarket amp.
- The one specific interface that I know has been confirmed (via the company's website and via phone calls from members and myself) to be for the MME is the PAC AP4-FD31. PAC customer support said that they are expecting more of these kits back in but do not have a definitive timeline. The last units they got sold out quickly. They did say it would be this year.
- There are others like NAVTV or iDatalink Maestro. I have not done the detailed research on them to validate if they make products that will work for the MME. The iDatalink Maestro is available for the Mustang coupe but the aftermarket amp that will interface with it is limited to Kenwood and Audison.
- The PAC interface kit comes with a wiring harness to connect to the OEM harness to receive power and digital signal. This connects into the interface.
- From the interface, you can run RCA or TOSLINK (if applicable) signal to the aftermarket amp. If you want to power each speaker you will need to have a six channel for the front doors and rear doors or a eight channel for all the speakers except the dash center. More below on that.
- The kit also has a connection harness to feed the amplified signal from the aftermarket amp back directly into the OEM wiring harness. No need to run new speaker wire, unless you want to upsize. Suggested video to watch if you do plan to replace or upsize.
- In addition, the kit comes with the t-harness to go between the head end unit (ACU as they call it) and the wiring harness for the three front speakers. The literature does not explain this but the harness (should be similar to the LPHFD31) provides connections for the signal input into the aftermarket amp, remote start, and connection for the amplified signal back into the harness. Again, this allows you to directly connect to the speakers.
- With the PAC interface, the front dash speakers have to powered by an aftermarket amp, per the PAC literature. I am not sure why since the PAC unit is specifically for the everything but the front dash speaker. However, if you are going to add an aftermarket amp to six of the nine speakers, why not do all eight or nine. If you are going to power the dash speakers, with an amp, you will either need to ...
- Put the amp in the rear. This would require running the input signal, and possibly the remote out (unless you jump the remote from the rear amp) from the front t-harness to the aftermarket amp. You then have to run the speaker inputs from the aftermarket amp to front to interface with the new t-harness. If you want to run all three speakers you will have to get a three or four channel amp. You could disconnect the middle speaker and go with a two channel amp. Also, you could use a two channel amp and have one of the channels power the mid. However, that gets complicated since the mid (3.5" speakers) and the tweeters (1" speaker) would have different frequency cross-overs.
- Another variable to this is to get a 8 channel amp to power all the speakers. Amp would be located in the rear. The center speaker would have to be either disconnected or powered by one of the 8 channels, as noted above. Of course, you could try to find a 9 or 10 channel amp which are not common.
- Put the amp up front. Process is the same as noted above but the runs got to the aftermarket amp in the front. There may be space under the dashboard. I l did some cursory investigation and certainly did not see open space large enough for an amp. There is no room under the seat due to height clearances from the seat cross support brace.
