IPC Lag...PAAK related?
JoshTX
Josh
Houston, TX
2023 Mustang Mach-E Premium AWD Extended Range
Picked up my new Mach-E today. Drove around (with the fob) without an issue for a while, got home, and set up the PAAK. A couple hours later, I took my son out for a drive using the PAAK (no fob), and we noticed the IPC was super laggy. The speed was totally inaccurate and jumping all around. When I engaged the turn signal, I could here the click click indicator but the arrow wouldn't light up on the IPC, or would show as a solid arrow several seconds later, after the signal was already off.
I restarted the car, and did a reset of the sync screen with the steering wheel buttons, but that didn't seem to solve it.
I took the car out again an hour later WITH the fob this time, and all was fine.
Has anyone else noticed this sort of issue? I wonder if it is PAAK related...Will do some more testing tomorrow.
MY21 J1 Premium RWD SR
It seems super unlikely this is associated with PaaK, but hey maybe... I suppose anything's possible.
In my 28 months of ownership, I've seen my IPC do this sort of slow/unresponsive thing exactly one time, earlier this year. It happened halfway through a drive while I was on a highway. Except in my case the IPC restarted on its own maybe 30 seconds after it started being weird, and then it was fine.
It was a bit freaky seeing the IPC restart while driving at highway speeds. When it boots back up, the speedometer quickly animates from 0 to your current speed. Pretty cool to see.
I don't know of any way that you can restart your IPC other than temporarily disconnecting the battery or fuses.
JoshTX
Josh
Houston, TX
Drove today using PAAK and had no IPC issues. So I guess that wasn't related.
Having your IPC restart on the highway would definitely be freaky!
