I just checked and last update I received was 2.3.0 (back in January). So yeah, I think you are up to date.Title basically says it all. Trying to determine if I’m up to date as someone who isn’t in EA.
No need to check. If you have Auto OTA turned on then it happens by itself and you get a notice in FordPass. If you have Auto OTA turned off then you get a message on the Sync Screen when an update is available. You can go back to driving your car as normal and you won't miss any updates. When available then you will be notified. ?Thanks everyone. Now back to my regularly scheduled checking for new updates.
? The wai-ai-ting is the hardest part ?
It is? Where?Edit: never mind, I found you can see it in FordPass.
This red line thing in FordPass is a forum theory, never confirmed by Ford.I just found the answer while browsing the forms earlier tonight. Just open the map in FordPass and browse around.
The thicker red lines on highways seems to indicate BlueCruise, as opposed to the thinner red ones or more common yellow.
Not the easiest to read or most convenient thing, but better than that one PNG.
Unfortunately that is not an indication of Blue Cruise availability. That is just the way Here maps, the map data provider, marks that type of road on its maps.I just found the answer while browsing the forms earlier tonight. Just open the map in FordPass and browse around.
