louibluey
- Joe
- Dec 21, 2020
- NY
- FE "Louibluey" GB
- retired
There a lot of questions through threads on how to jack / lift Mach-E. Maybe some variations are okay, particularly if the load is spread.
From the pdf, there is a very specific area between the triangle marks on the plastic strips which is suggested. It is the just under 3" strip inside of the aluminum rails with holes which are actually part of the battery pack and which aluminum battery rails are not to be used for jacking lifting (?), and which can be ripped (shipping example), or crushed.
The approved lift or jack area is the thin strip between /the outside plastic strip (with the triangles) and /the inside aluminum rectangular battery rail.
In the lift examples, it would seem that many reviewers are technically lifting incorrectly using the rectangular aluminum channel, instead of outer metal (steel?) strip.
I guess (?) to lift at least technically correctly, it takes something like a rubber jack pad / block that can be between the typically wider jack head surface and the relatively thin (2 1/2" to 3") metal rail which is inside of the rectangular aluminum battery member.
From the pdf:
So, this (wrong?) example is probably near or between the triangles, but on the wrong member, the aluminum rectangular rail:
This appears to be another wrong (?) example as to the jack, the safety stand appears to be on the correct strip:
From the pdf:
