Job2 FP Data Missing After Recent FDRS Updates (also OTA 2.8.2)
DevSecOps
Todd
CISO
Update 06/22/22 - issue resolved with the subsequent GWM update here: https://www.macheforum.com/site/threads/06-20-22-gwm-job2-obcc-job1-2-updates.18891/
Update 06/24/22 - This update, which broke my charge data is included in OTA Power-Up 2.8.2. Other Job2 owners who get 2.8.2 might experience the same issues that I had. There is no fix other than installing the newer GWM update via FDRS. Thanks to @WyldStallyn for catching this.
Original Post:
Wondering if anyone here with a Job2 has done the latest GWM update?
After doing the update I'm experiencing limited data in FordPass. I can perform all normal operations with the exception of charging. I get no notifications of charges in progress, no way to "charge to 100%", no charge logs or ability to modify the destination settings.
If anyone else has performed the GWM update from Late May/Early June on either job1 or job2 chime in with your experience.
WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
No issues for me other than the FordPass bugs since 4.16 on iOS. GWM updated last month.
I'm not sure I have ever had a notification of charge in progress; however, I can view that charge is in progress, receive notifications of completed charge, and am able to activate charge to 100%. I do have charge logs as well.
Regarding destination settings, I don't recall if I have modified anything since the GWM update but I do believe I did make some changes from the app with no issues.
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
I updated GWM on my 2022 (17th Feb 2022 build date) - no issues here. Charge in progress working ok, hitting 80% SOC notifications working ok too. Charge logs all look good.
Ford Mustang Mach-E Job2 FP Data Missing After Recent FDRS Updates (also OTA 2.8.2) 0D93AF74-C59C-4553-B7B4-E54E0FF1EEC6
DevSecOps
DevSecOps
Todd
CISO
Yeah I didn't update FP and the car on the same day. So I know it's because of the updates on the car. I did additional updates at the same time. Most of them powertrain related so I don't think those would cause the issue.
I have received confirmation from my sources that there might be an issue. It may just affect some and not others.
As you can see from the below. The same day I updated the GWM, and other modules, is the same day that I stopped receiving charge data.
Ford Mustang Mach-E Job2 FP Data Missing After Recent FDRS Updates (also OTA 2.8.2) 1655134996049
Ford Mustang Mach-E Job2 FP Data Missing After Recent FDRS Updates (also OTA 2.8.2) Screenshot_20220613-080912
Ford Mustang Mach-E Job2 FP Data Missing After Recent FDRS Updates (also OTA 2.8.2) Screenshot_20220613-080904
The last GWM update on my Job 1 was on May 1st, but I didn't have any ill effects.
DevSecOps
DevSecOps
Todd
CISO
I was told that the rollout of the current GWM was halted so for those who haven't performed it, you might want to hold off. Looks like I might be in the minority with issues, but for some reason Ford has stopped the rollout of it.
Neil4Real
I did all the updates you did on the same day for my GT PE, 11/2021 build. Not experiencing the same issues. Seems like this one took them a while to catch. Have you attempted to re-pair your phone and re-setup PaaK to see if that fixes it?
DevSecOps
DevSecOps
Todd
CISO
Charge data is present regardless of PaaK so I have not. PaaK works fine and so does all remote function.
I have received info that I assume is probably not for public consumption. So, I'll just say I'm gonna wait a week and maybe there will be a fix. Fingers crossed.
DevSecOps
DevSecOps
Todd
CISO
DevSecOps
DevSecOps
Todd
CISO
Looks like we have confirmation that Job 2 OTA 2.8.2 installed the same GWM update that broke my charge data. Since I installed it prior to the OTA I experienced this issue ahead of what, presumably, will be an onslaught of others here with the same issue.
I'll update the thread to provide more detailed information within the next day, but this could be a very wide spread issue with 2.8.2 rolling out.
With charge data like this, what is anyone really going to miss?
DevSecOps
DevSecOps
Todd
CISO
It's not just charge data. It's also the main screen % of battery left, range, ability to charge to 100%, trip data etc. What I missed the most was charge to 100% because I take a lot of longer trips and use that often. A few times I had to change my charge settings manually in the car, because that was also broken in the app, and then remember to change it back when I was done with that trip.
scoopman
Bay Area
2023 KIA EV6 GT, 2021 VW ID.4 Pro S
former electric pony jockey
So the power up ota mechanism will install earlier versions of software in a module over a newer version?!
That’s some awesome “update” logic they have there.
On a positive note.....at least it is consistent. :)
OWG
MA
2021 MME Premium Extended Range AWD
Beginning the onslaught! Confirming the issue in the Job 2 OTA 2.8.2
https://www.macheforum.com/site/thr...build-2-oct-21-early-access.18964/post-450764
